Boring the Throttle body
Old May 2, 2003
cdmx's Avatar
Anyone think about doing this with say a dremel...A DIY
Ive been asking around and havne't gotten anything yet, so i wondered if it woudl be hard or if i could F*ck something up if i tried to do it myself with a dremel. Anyone think about doing this? Grey? someone do a dIY
Old May 2, 2003
djmota's Avatar
you need to make the throttle body perfectly round. this takes a lathe or at least a drill press with the correct tool to cut it with.... no way with a dremel ...also you need to replace the butterfly with a larger one
Old May 2, 2003
cdmx's Avatar
oh, i wondered about that...the "butterfly" that is...now i know what its called.
Old May 2, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
Ive seen it done in mags with a dremel
Old May 2, 2003
cdmx's Avatar
i guess its too risky right? i dont want to mess it up...where would i get a larger butterfly
Old May 4, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
yea... a dremel with unknown precision... vs a drillpress or metal lathe with a nice presision... yea u take ur pick
Old May 4, 2003
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
You could get it extrude honed..little pricey but gives awesome results
Old May 4, 2003
BJAI's Avatar
BJAI is an unknown quantity at this point
how much gain will this have?
Old May 5, 2003
cdmx's Avatar
^what does that mean???
Old May 5, 2003
WannaBFast's Avatar
well u could always get a new, bigger throttlebody
Old May 5, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
Appoximently, how much would it cost to bore out a throttle body?
Old May 5, 2003
slystad810's Avatar
Yeah how much would it be if u took it off and gave it to a shop approximately?
Old May 5, 2003
Meatman's Avatar
Meatman is an unknown quantity at this point
I don't think the gain would be worth it. Wouldn't it be better to just get a new intake starting from the block??
Old May 5, 2003
RoadRunner's Avatar
i'd ask someone else to do it, like at a shop. so that way i wont worry about messin it up
Old May 5, 2003
Spider883's Avatar
9K Redline Owns U
i have had it done.. do not do it with a dremal.. it needs to be bored by a machine and u need a new butterfly
Old May 5, 2003
Tiki's Avatar
Tiki is an unknown quantity at this point
whats a butterfly?
Old May 5, 2003
GideoN's Avatar
Spider883: How much did it cost to get it done? And what kind of difference did you have?
Old May 5, 2003
GideoN's Avatar
If I am not mistaken, the butterfly is the rotating piece within the throttle body that controls the amount of air that comes through. Correct me if I am wrong though
Old May 5, 2003
Spider883's Avatar
9K Redline Owns U
well i have i/h/e p/p head, and bored tb so it makes more of a difference for me but just alone probably 1-2hp
Old May 5, 2003
Spider883's Avatar
9K Redline Owns U
oh price was 175 for me
Old May 5, 2003
GideoN's Avatar
Spider883: What kind of horsepower do you think you are getting with all of those mods?
Old May 5, 2003
GideoN's Avatar
I understand that probably not much but hey, still like to get an idea. Throttle body work would make more of a difference with acceleration, huh?
Old May 5, 2003
Grey's Avatar
DIY King
I thought about doing this myself, but I don't have a drill press that's precise enough. The one I have is fine for wood, but for metal the tip vibrates too much. If I had the tight tool, then sure I could do it. Just use a lathe and bore it out until the bottom doesn't have this little lip anymore.
Then with a lathe and a sanding bit do cross-hatching. First the sanding bit has to have only light pressure on the inside of the throttle body. Then you turn the bit at relatively low speed and push it through the throttle body opening at a constant rate. Then reverse direction (or if not possible reverse throttle body) and do it again.
Larger diameter throttle body will give you more flow and cross-hatching will make the air flow across the sides of the throttle body with minimal friction. Then all you need is to match up the butterfly valve with the throttle body opening. You could again use the lathe to to take some material off and match it up.
Old May 5, 2003
GideoN's Avatar
Leave it up to Grey to figure something out! By the way, your icon of Vash is AWESOME!
Old May 5, 2003
Grey's Avatar
DIY King
Thanks. Second compliment I got for it. I think it's a keeper. Vashu da Stampededoda!!!
Old May 5, 2003
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
if your going to bore the TB its worth it to p&p as well because all that stuff realy works well together to increase airflow, with bored TB, P&P
head, increased compression, and good I/H/E , you can expect knowticeable gains, espesialy with a new fuelpump/reg and some sort of FCU or jet-like chip you can realy crank it up. add internals and some more milling&bolt ons and youve got yourself a good all motor car... with all that id guess 30 hp gain if its properly tuned by pros on a dyno. ive got money saved up for this this summer i plan on doing the above and will get info up on it when i start.
Old May 5, 2003
Grey's Avatar
DIY King
I'll be looking forward to that. Sounds interesting.
Old May 5, 2003
GideoN's Avatar
As will I. Please keep us updated!
Old May 5, 2003
cdmx's Avatar
wow, i thought this thread was dead....Great info guys...and as always thanks for the input grey....(btw i was the first compliment about the vash icon...its tight!)
Old May 5, 2003
flotsamm's Avatar
I think before you bore out the TB, you first need to know how much CFM it flows stock. For all we know it might already be flowing well enough that boring it out might be fruitless... dunno.
