Clearing headlights using oven
Old May 22, 2003
chuckles2001's Avatar
chuckles2001 is an unknown quantity at this point
Ok, at one time I heard of someone using an oven to loosen the sealent in the headlights. I was wondering if anybody had the temperature the oven is suppos to be set on?
Old May 22, 2003
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
I've heard about someone doing the same things but for the tail lights.. The guy had a 2nd gen integra, put the tails in the oven and I guess the red stuff melted off or something! It'd be pretty interesting to find out the temp it has to be set at if anyone knows.
Old May 22, 2003
dj pyrotechnics's Avatar
dj pyrotechnics is an unknown quantity at this point
trial and error!
Old May 22, 2003
Phanibal's Avatar
Phanibal is an unknown quantity at this point
You should put it on like 250 but be careful to check constantly, also i used a hair blow dryer which seemed to work the best it just takes a little longer thats all, be sure to reseal everything with silicone and lots of it to ensure it doesn't fog.
Old May 22, 2003
Chyna's Avatar
Chyna is an unknown quantity at this point
I set the oven temp to about 200 and checked it after about 2 minutes. The glue was soft enough to pull apart after that. Just keep an eye on it and you will be ok.
Old May 22, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Just use the lowest temp. I put mine in at 250 (I think) for about 10 minutes...but it smelled a bit of melting plastic when I took them out. But everything was fine. Cleared mine last Dec and no fogging at all.
-Kre
Old May 22, 2003
tripledoublegs's Avatar
Euro-Spec
250 degrees. My friend did it, but he used too little sealant and they were all foggy. If you do it right, it looks really nice.
Old May 22, 2003
7thGenerasianCivic's Avatar
Make sure you are there and keep a close eye on it! Just some advice...
I forgot what temp I used...but it sure is better than using a heat gun...my friend basically melted his RSX headlights...MUHAHAHAHA!!!!!!!!!!!!!!!!!!!
Old May 22, 2003
cambo's Avatar
I wish I was asian
500 degrees at 2 minutes!
no...i did it at 200 degrees for both 7thgen headlights and 2000 accord lights
Old May 22, 2003
robbclark1's Avatar
Retired suspension supermod.
I did mine at 250 for about 3-5 min. Keep an eye on it. It is way easier than a hairdryer.
Old May 22, 2003
GreenNVicious's Avatar
Newbie
Yep, did it that way too! 250* for 5-7 mins, but keep watching it.
Old May 22, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
I never put mine in the oven, I cleared my coupe headlights and only used a hair dryer and a couple of screwdrivers. Came off really easy.
Old May 22, 2003
aphillippy's Avatar
aphillippy is an unknown quantity at this point
240 at 7 minutes... also do it when you are putting it back together and you wont even need to use any extra sealant
Old May 22, 2003
KeNsHiN's Avatar
LEVA
i agree with 250 for 10 mins or less
Old May 22, 2003
TeLLy's Avatar
Yes, it's an Acura EL
250, just under 7 mins. Trust me I done over a dozen pairs already...just remember to watch them, the black plastic melts....
Old May 24, 2003
snoopbag's Avatar
snoopbag is an unknown quantity at this point
Just put them out in the hot sun for 20-30 minutes and your good to go.
Old May 24, 2003
ImPulse's Avatar
me, osofast2001 and mndthegap1
just took the headlights appart and i added a nice border of silicone to it... just happends that the following day the left headlight fogged up completley, and the right one fogged a lil, but went away 100%...
A couple of days later i took em off the car, and blow dryed em for about 10-15 mins each on high, and put like an inch of silicone around the border =] now, none of em fog up
Even if you do put em back in the oven, i would add some clear-water proof silicone to it, just to be on the safe side
Old May 24, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
Good deal, then I guess I have something to do if I don't get called in for work. Thanks fella's
Old May 25, 2003
drang01's Avatar
drang01 is an unknown quantity at this point
giving serious thought to doing this. did you have to remove the bumper to clear the lights?? and if anyone knows off hand I think someone painted the chrome black.. any ideas how they did it ??
Old May 25, 2003
drang01's Avatar
alright so I did a search on the painting bit and
got the info on that as for the bumper will someone
answer that one for me thanks.
Old May 25, 2003
clownprince's Avatar
Ricerus Maximus
15 min at 175 is what i did, worked like a charm.
Old May 25, 2003
nuffsed's Avatar
what kind of paint do I have to use to paint the inside...
i have APC Altezza tail lights and I want to paint the chrome.... any suggestions on how to open them up so that i can paint them?
Old May 25, 2003
GideoN's Avatar
If you look in the DIY section, it will tell you step-by-step how to remove the lights.
As for the paint, 500 degree paint as far as I know and I believe some have sprayed a clear coat too.
And as for the tail lights, not to sure about that.
Old May 25, 2003
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
you shouldn't need to bake the coupe headlights, only the sedan. if you are doin a sedan keep the oven at 200-250, no longer than 8 min.'s should be easier than splittin a prostitutes legs
Old May 25, 2003
GideoN's Avatar
Why shouldn't you have to do it to Coupe lights? What makes them different?
Old May 26, 2003
TeLLy's Avatar
Just had to post up another one - when blacking out, try using Duplicolor Engine Enamel...it sticks well to the chrome, and dries real quick.n Better than the generic flat black stuff you find in Canadian Tire or Walmart.
Old May 26, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
I didn't heat mine at all. It came apart easy with a screwdriver. Just open them slow.
Old May 26, 2003
GideoN's Avatar
I had an extra head lamp from a run in and that was a pain in the *** to separate. I would definently recommend some type of heat source. I am planning to try an oven when I clear my headlamps.
Telly: where can you get Duplicolor Engine Enamel?
Old May 26, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i didnt even use a hairdryer, just screwdrivers and some muscle!!!
Injen
Old May 26, 2003
civicvtec1ps's Avatar
Search and Learn
i didnt have to use oven at all...
i just used flat screw driver.
