cleaning out fuel tank?
Turbo Member
Rep Power: 306 cleaning out fuel tank?
Iv'e noticed that over the past few months Iv'e lost a lot of performance, and throtle response.
And the other day my car started leaning out for no reason. This convinced me that I had to have a fuel delivery problem.
I removed the fuel line from the fuel rail and blew 20 psi of copressed air into it to try and clean the fuel filter out. After a short test drive I noticed a big difference in power and throtle response. So I know that the fuel filter needs to be replaced.
Here's the problem. There is still going to be debris in the tank after I replace the filter. How do I get that stuff out? Should I just empty the tank through the access port under the rear seats and wipe the tank out w/ a rag? or should I just drop the whole tank out of the car and flush it out?
Rep Power: 0 Hey, where exactly is our fuel filter? And how much does a replacement cost?
If that filter eventually needs to be replaced on our cars, I wonder why our manuals never make any mention of it? Even all those "shortened" servicing schedules handed out by the dealers don't have the fuel filter mentioned. WTF?
As for cleaning out your tank, I think that's overkill. Replacing the filter should be good enough.
Turbo Member
Rep Power: 306 the filter is inside the fuel tank , and cost $25. So Id rather do the job right the first time instead of having to replace an expensive filter again.
bmy
02-06-2002 12:17 AM
bmy
01-24-2002 07:29 AM
