Need info on HID's
Old May 4, 2003
dru106's Avatar
ThE CoRRupToR
Need info on HID's
I dont know much about how they work and how to install them. Does it use a lot of amperage? Should I install myself or pay someone to do it? Does it get really hot inside the headlight housing?
Old May 4, 2003
dragoon's Avatar
Yes, initially. The current drawn to "ignite" the HID bulbs is going to be something like 13 amps, rather than the 7 of OEM. A wiring harness is strongly recommended!
Should you install yourself or pay someone to do it?
This is a very debatable question. If you know what you're doing, go for it. Take all the same precautions as you would for any other electrical work.
HID runs cooler than halogen.
Old May 5, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yes, I also think it is very obvious to NOT TOUCH THE BULB with your hands ... the bulb will get oil on it from your hands and because it gets very hot, the glass will explode ...
Old May 6, 2003
Voiceofid's Avatar
End Bringer
that's for those cheap imitation hid bulbs
true hid bulbs wouldn't blow that easy, it's insulated, because the arc releases radiation, the bulb has to be thick enough to prevent radiation leak
Old May 6, 2003
Connie's Avatar
If your talking about imitations then you don't need to worry, it won't pull too much power...about real hids I am not sure....
SolidHollow
15
Sep 13, 2015 11:18 AM
Gsxtacy
Sep 12, 2015 01:09 AM
MamaBear2015
Sep 4, 2015 09:04 PM
