RSX 5spd Shift Mechanism
Old Jul 24, 2003
littlecow's Avatar
littlecow is an unknown quantity at this point
Has anyone tried using the actual shifting mechanism from an RSX. Right now I have a Revo short shifter but it looks like its getting worn out, only after ~5 months of use. Has anyone tried it or even knows if it can be done?
Old Jul 24, 2003
CarbonFly's Avatar
it will work. YOu can use it if you want.
Old Jul 24, 2003
YES_part2's Avatar
YES_part2 is an unknown quantity at this point
arent rsxs hydrolic and ours cable?
Old Jul 24, 2003
CarbonFly's Avatar
no.
they are the same. even my REVO SS is actually made for the RSX.
Old Jul 24, 2003
NeonImpact's Avatar
Forum Sponsor
what do you mean its actually worn out?
slides in and out of gear too easily?
Old Jul 24, 2003
littlecow's Avatar
I took apart the mechanism again to install the metal bushings and I noticed there was a pile of powder that seem to have come from the ball joint as you move side to side in neutral. Could be a defective item...but since I have the RSX shift ****, might as well go with the original RSX shifter.
Old Jul 24, 2003
NeonImpact's Avatar
Forum Sponsor
RSX **** is a good choice with that shifter..
im gonna get one from a dealer around here i suppose..
i have my Revo SS, but im most likely gonna do the install with FlyRiceRacer..
Old Jul 24, 2003
Alex1's Avatar
if u get that, get the type - S so u get the OEM short shift adapter with it. i mean it has one extra gear but u can just ignore it im guessing right??
Old Jul 24, 2003
cdmx's Avatar
he must be really slammin it in gear
Old Jul 24, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Is that even possible?
Old Jul 24, 2003
CapYoda's Avatar
Escaped Convict
ah geez. lol.
the RSX base shifter assembly is very similiar to our stock assembly. its not shorter, nor is the cable located differently... although the curve is a bit different.
I woulnd't use the Type S shifter assembly on our car.. since the curve is a lot diff... its not meant to be used on a 5spd.
it'll work, I think.. there wont be any extra gears.. that doesn't have much to do with the shifter assembly, thats not what determines what gears u can shift into.. the two cables attached to the tranny is what determines it...
I'd just get another revo/obx, or see if u can get a replacement...
dont they have any warranty? heh.
Old Jul 24, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Re: RSX 5spd Shift Mechanism
Are you sure you lubed that Revo up real good? Sounds like you were shifting it un-lubed. That's the only reason I can gather about what happened.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
JoeB16
61
Oct 16, 2003 07:58 PM
Mokushi
Jan 31, 2002 02:15 PM
pazzmore
Dec 24, 2001 07:39 PM
AFlyer
Dec 22, 2001 01:18 PM
