diy a/c control relocate
yea i was thinkin bout solderinthem but theres alot of wires and each one man id be there for a while im gonna relocate them to the side of the center concole on the drivers side or under the e-brake
Use sodder, I do alot of custom wire extending installs for friends and I sodder each one because butt connectors will eventially let up. If you can the best way to do it is to go to Honda and ask them if they have matching connectors that is the amount of feet you need or longer and if longer strip each wire and use pin tools to set them in the connectors. Try to get matching connectors and line up the pins DON"T MIX THEM UP!!
With a lot of wiring projects I use power connectors from PC's. They have the capacity to hold 4 wires and are easy enough to plug/unplug but normal bouncing around in a car will not cause them to come apart. Also, they are fairly cheap to obtain.
FutureCivicOwnr
Aug 11, 2015 10:59 PM
Jul 14, 2015 03:39 PM
