Exhaust Hitting Sway Bar, How To Fix????
Old Jul 25, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Question Exhaust Hitting Sway Bar, How To Fix????
Hey everyone, today I brought my car into honda to get some warranty stuff done to it. When I went there, I told them that al slow speeds, going over bumps and turning corners, my suspension squeaks. It sounds like a trampoline. Well when I went to pick up my car, they told me that it was my exhaust hitting my suspension, my sway bar to be more specific. I have an OBX B3 Bomb Cat-back exhaust. It is really annoying having my car squeak all the time. I can't raise my exhaust anymore or it will touch my rear bumper and make an even worse rattling noise. Is there anyway to fix this problem? Id really appreciate you all's help.
Old Jul 25, 2003
Weaponx12o's Avatar
have a shop bend the exhaust hangers so they sit higher
Old Jul 25, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
i had the same exhaust system you have, and never had this issue, but bending the hangers is the best and first thing to try
try to bend them your self
Old Jul 26, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Be careful if they adjust the hangers that the tip isn't too close to your bumper.
I fixed the problem on my car by selling the exhaust and keeping the sway bar.
Old Jul 26, 2003
ZSKCivic01's Avatar
Extreme Member
Ok, when I originally got my OBX system, the brackets were too small so basically the exhaust was flush with my rear bumper. I got the brackets bent out a little so my exhaust wouldn't make contact with my bumper, which when making contact, started melting my bumper slowly. If I take it into Meinke, is there anything specifically I should ask them to do? Or better yet, how far away should the piping be away from my sway bar to prevent both from making contact?
Old Jul 26, 2003
VTEC01EX's Avatar
At least a half inch if you have the space to do it. I solved my problem when I still had the exhaust by getting some foil-covered foam tape (I believe for plumbing). I wrapped the portion of the sway bar that was hitting with it, and I wrapped one turn around the exhaust. Took care of it without a problem, and seemed to hold up in the rain pretty well.
Old Jul 26, 2003
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
You could also decrease the pipe size. That might buy you a little clearance between the exhaust and the sway bar.
Like so:
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
Firefly
Nov 28, 2001 06:13 PM
jessepimpride
Nov 13, 2001 05:59 PM
