need help on revo short shifter ASAP
i bolted it down and connected the cables and everything and tried shifting but it doesnt seem to want to go to first or second, like it barely moves what did i do wrong and howe can i fix it?
it seems like it just sticks a little bit but i lubricated everything and i dove around the block so it works, if you got greys upgrade kit do you need both e clips at the same place and where does the second washer go, one goes on the cable below the shift know and the other one where?
I only used one E clip to hold the linkage cable. I didn't use the second one.
Both washers got on the bolt that holds the cable. The rubber side in, metal side out. It should be on either side of the cable.
velozp
Dec 13, 2015 11:28 AM
rayaan_wasty
Sep 14, 2015 02:00 PM
Touge
Sep 1, 2015 11:25 PM
