Help with Razo Up shift indicator. What setting to put at?
Old Jul 26, 2003
02SilverSiHB's Avatar
K Motor Lover Baby!
02SilverSiHB is an unknown quantity at this point
For those not familiar with it, here it is:
shift light
control unit for selecting rpm's for green and rpms for red lights
The Red comes on when you reach the max rpms you want.
The green lights up when you are at the rpm you want for launching at the strip. This can also be set for autocross to where if you fall below the desired rpm it will light up. You just press a switch for the desired affect you want, either above or below the preset rpms.
When I start the car, the green light is on and I have it set to come on when it goes below a certain rpm (not sure what rpm, but the **** is turned to a low setting)...to test it out. I rev it all the way and the light doesn't go off. The red one doesn't come on either when I hit the rev limiter and I have the red rpm set to a low setting to come on.
There are 6 switches in the rear and I have no idea what to set them at. The manual is written in poor english, but sounds like I should have the switch down for 4, meaning I have 4 cylinders. So I'm not sure if I have that part correct, or if I have the thin black wire spliced into the wrong blue wire.
Old Jul 27, 2003
K Motor Lover Baby!
never mind guys. I got it working now. I had the back set correctly....number 4 down and the rest of the tabs up. I just had the wrong blue wire, go figure The blue wire was on the far left connector to the ecu.
Blazz
Jun 4, 2015 01:04 AM
usajags84
May 30, 2015 06:49 PM
jimmyfloyd
May 20, 2015 07:06 PM
cruisers10
May 12, 2015 10:46 PM
What_It_Do
May 10, 2015 05:31 PM
