WTF...i can't get the a/f gauge to work
Old Aug 4, 2003
reytito's Avatar
hey gimme a hand here...i'm installing my a/f gauge. its a simple 3 wire connection, which is why i'm so pissed that i can't get it working. i have the o2 sensor tapped. ran that wire into the car where its soldered to the sensor wire on the gauge. the gauge is grounded to a screw in teh engine bay. and my power is from the cig lighter. checked all taps, soldering, and connections. cept its NOT WORKING. meaning, no LED's light up, no sign of any power. now i also would like to mention that this is not the first time ive had trouble with gettin power from the cig lighter. i tried puttin in neon lights inder the seats, but it never worked when i tapped into the cig lighter's power and ground wires. i eventually gave up on the lights. my cig lighter works perfectly fine. so why would the power wire not work??? i don;t understand. now where else can i draw 12v from? any help would be appreciated. thanks.
Old Aug 4, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
That sounds messed up...
Have you checked the stupid things? Like you tapped the correct wire on the Cig lighter harness, the wires you spliced to the gauge wires are spliced to the right ones? You tapped the correct O2 sensor wire?
If that stuff all checks out, you can get 12 V somewhere in the ignition harness, but I don't know which wire it is. Sounds kinda wierd. Have you unsuccessfully tried wiring it up before and maybe fried it? Or maybe it's just a dud?
Old Aug 4, 2003
reytito's Avatar
nope i tried wiring it for the first time today. all the wires i tapped into are the right ones. i'm already pretty ticked off..is this turns out to be a dud, i'll be real pissed. but chances are...its not the gauge. i need to try another 12v. anyone know which wire to tap into on the ignition harness to get my 12v? pics? any help will do.
Old Aug 4, 2003
reytito's Avatar
well i tapped into my headunit's 12v and the gauge lit up. cept now its running fully rich. so i'm thinkin somethin's up with my ground. grr. i won't have time to reground till tomorrow. double grr.
Old Aug 4, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Thumbs up If I am not mistaken..
I remebered when I hooked up all my lights and if I remember correctly, the Cig lighter will NOT give power uness the engine is on. I have a 2K1 civic, and not sure if it changed in the next couple years of production, but that's how mine was.
Old Aug 4, 2003
reytito's Avatar
the engine was on. any 12v power source won't have power untill the engine is on.
Old Aug 4, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
What color wire did you tap to on the sensor?
Old Aug 4, 2003
reytito's Avatar
the black one.
Old Aug 4, 2003
Jap-Euro Fusion
Which screw in the engine bay is it grounded to? Hook it up to a grounding strap. Undo the one on the front right corner of the engine, slip the wire in and put it all back together (don't forget to put the strap back on). Then try it. If you've got it on a screw on a painted surface, it may not be contacting.
Old Aug 4, 2003
reytito's Avatar
i have it under a screw along the side of the engine bay...i was sure to scrape it to metal...but i will try a grounding strap. by that i assume you mean the thick grounding wires?
Old Aug 4, 2003
Jap-Euro Fusion
yeah... like the one that goes from the engine block to the front rail... or, just hook it straight to the battery ground.
Old Aug 5, 2003
reytito's Avatar
well it wasnt ground afterall. it was my o2 sensor tap. NOTE TO ALL:
-if you're gauge is stuck on RICH - your sensor tap is bad
-if you get nothing, either bad power or bad ground. (if you have bad ground...the guage won't work at all.)
Old Aug 5, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
Glad top
Old Aug 5, 2003
Green Civic's Avatar
So its working? Your o2 sensor wasnt tapped good enough? So the install, 1-5 rating? How was it? Pics of where you put the gauge?
Old Aug 5, 2003
reytito's Avatar
should be very very easy. but i'm a retard. i'll have pics up tomorrow. i got a single pillar pod.
Old Aug 6, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
Hey Titus, I'm glad you got your gauge to work. I will be installing mine in the next 2 weeks, whenever it gets off back order.
Old Aug 6, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
why are you all tapping the sensor at the sensor itself? i tapped mine at the ecu...seems to work fine...
Old Aug 7, 2003
Jeff's Avatar
From what autometer instructions say your sopost to tap it at the ecm but it also works from the 02 sensor. I tapped into mine at the 02 sensor just because it was easier to get to.
Jeff
Old Aug 12, 2003
ohmysac's Avatar
easier to get to? pop off the stops in the glovebox and let it fall..and there it is!! i think thats a bit easier than running a wire outside...plus it helps that i have a service manual to look at
Bruce.Ringler
Jun 18, 2015 08:12 AM
werdnahall
May 17, 2015 11:37 AM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
Jhonda
Nov 9, 2001 09:48 PM
