Subwoffer question
Old Jul 25, 2003
CivicRacer2001's Avatar
CivicRacer2001 is an unknown quantity at this point
Subwoffer question
sup peeps i just bought a new sub yesterday poweracustics daul voice coil
and i hooked it up the way it said in the instructions so am using both coils..
now my amp is getting relly hot and turning off and on on me cause it over heating
dose any body know what the best way 2 hook up a daul voice coil sub to a 2 channle amp?
Old Jul 25, 2003
djmota's Avatar
gonna need more info to help you out like the power rating on the sub and amp ...if the amp is bridgeable ect.
mod should probably move this to ICE so more people can help
Old Jul 25, 2003
FALKEN's Avatar
Civicforums Junkie
Originally posted by djmota
mod should probably move this...
yep
Old Jul 25, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
sounds like that sub is just pullin more power then the amp is able to give
Old Jul 25, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
ur not runing the amp stable... u need to find what OHM the amp runs and run the speakers at the same OHM.... thats why its heating up ... ur gonna blow ur amp if you dont match the OHMs
Old Jul 25, 2003
FALKEN's Avatar
Civicforums Junkie
nice avatar 'cracka'
Old Jul 25, 2003
xtiszx's Avatar
Cracka
thanks, i like it
even tho i stole it from some other dude on another fourm, and i thought the cracka went nice with it
Old Jul 25, 2003
xtiszx's Avatar
Cracka
didnt think about that
Old Jul 25, 2003
ok the amp is a 600 watt kennwood and yes it is bridgeable
the sub is i thing 900 watt daul voicecoil poweracustic...
i hooked the the sub up like this ran the - to the other side of the - for the voice coil
and hook the + to the other + the ran the amp - to - and + to +
the its bridged to my amp now which am using a - from one of my channles and + from the other
i be better with a diagram so sorry if am confussing
Old Jul 25, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
Don't run it like that. Just hook it up as if it were two different speakers. Don't combine any of the wires in any way. You MIGHT be able to get away with it if your amp is stable to 2 OHMs in bridged mode, OR if your speaker is 2 OHMs per coil you can run it in series and get 4 OHMs out of it. Anyway, neither of those is probably the case, so just run it like you would two different speakers. Forget all that bridging stuff. Any more questions ask me, I've done installs for about 8 years now. I know a thing or two.
-Keith
Old Jul 25, 2003
xtiszx's Avatar
Cracka
alot of people on this site know ALOT about audio, he doesnt just need to ask you
Old Jul 25, 2003
Mags's Avatar
Whoa, easy killer. I was just trying to be nice. No need to flame.
Old Jul 25, 2003
xtiszx's Avatar
Cracka
i wasnt flaming bro,
Old Jul 25, 2003
Mags's Avatar
what a relief
Old Jul 25, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
see that ? thats the worlds smallest violin.
Old Jul 25, 2003
DigitalShin's Avatar
DigitalShin is an unknown quantity at this point
You may want to use a cap. as well. Worked great for me.
Old Jul 25, 2003
byrd819's Avatar
byrd819 is an unknown quantity at this point
Go to www.RockfordFosgate.com They have wiring diagrams for different combinations. As far as a cap I don't think you'll need one. I heard they were a waste of money.
Old Jul 25, 2003
Byrd-
Definitely not a waste. Helps a lot. I've got a Sony Xplod 1000 watt amp pushing two Pioneer 500 watt subs. The Cap prevents the dimming effect when ever hard bass hits. So it's something I would recommend getting.
Old Jul 26, 2003
pheaton's Avatar
A descendant of 2k1civic.com
I would get a cap. . It helps keep the bass more consistant. . Also .. what are the OHMS on the sub? What's the least ammount of OHMs your amp can do?
Old Jul 26, 2003
cdmx's Avatar
he wont blow the amp...it has that safty feature where it will cut off when it gets too hot..whats it called some sort of special circuitry
Old Jul 26, 2003
pheaton's Avatar
Yeah .. most new amps do that now. . Mine does . . When it gets hot it just shuts down. . Which is good. . Just a safety feature. . It goes to sleep instead of dying.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
