Compression ratio? what is that?
Old Aug 6, 2003
Bigmac's Avatar
Bigmac is an unknown quantity at this point
Can someone tell me about compression ratio?
Old Aug 6, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
http://www.7thgencivic.com/forums/sh...o&pagenumber=2
Some decient stuff in here.
Punch it into google, you'll get a much better explaination. It's a little complicated.
Old Aug 6, 2003
stlblues13's Avatar
stlblues13 is an unknown quantity at this point
It is fairly technical, but the short answer is the compression ratio is the how much volume in air in the cylinder is compressed into the fuel. For example, 10:1 means ten parts air to one part fuel. Compressing the air/fuel mixture makes it more volatile for the spark to ignite the explosion in the cylinder. That is why, in general, higher compression results in more horsepower. The problems come when you get too much compression and/or crappy fuel which causes detonation (pinging). What happens is the fuel/air mixture explodes before the piston has gotten to tdc (top dead center) and the spark ignites. The effect is to basically hammer the hell out of your pistons/valves/cylinder head.
Old Aug 6, 2003
dezod's Avatar
7thgen Power Maker
stlblues13
Old Aug 6, 2003
Jap-Euro Fusion
Compression is totally volumetric. Air fuel ratio is totally different and is ideally 14.7:1 (for Gasoline). A/F plays a part in how high your compression can be... you need more gas to go higher and higher octane because it doesn't detonate as easily, but in the calculation of compression ratio, it plays no part.
Compression ratio in a dumbed down version is the ratio of the cylinder volume at bottom dead center of the stroke, to the volume at the top dead center of the stroke. But you also have to factor in the head gasket thickness, head volume, and the deck height to get it right.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
Sep 27, 2015 11:33 AM
NROD315
Sep 12, 2015 02:46 PM
darwin-t
Aug 15, 2015 10:51 AM
