Help with NOS Install
Old Feb 15, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
I have a buddy who is hooking up NOS in his car (not a civic). However, this is a general question/problem. Maybe someone can help. Everything is hooked up correctly. The only problem is when he hits the button (without the bottle open), nothing comes out of the fogger. The gas seems to leak around the bottom of the fogger but nothing is sprayed. His post to his own forum is attached at the bottom of my message, maybe you can make more sense out of it. Please post a reply if you have any ideas/suggestions/prior knowledge.
Thanks,
E
"Well actually, the fogger leaks gas when I hit the button and I can hear the solenoid click but no spray and no engine bog.
I took the gas line off the fogger from the solenoid and had my dad hit the button and it shot plenty of gas out of the line its just when I have it screwed on as tight as I can get it the line leaks a little and basically does nothing.
Any suggestions?
Thanks,
Josh "
Old Feb 15, 2002
2k1EXracer's Avatar
2k1EXracer is an unknown quantity at this point
he probably has some crap clogging up the nozzle
Old Feb 15, 2002
any other ideas?
Old Feb 15, 2002
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
FIRST CHECK IF THE "JET" IN THE FOGGER IS MESSED UP
ARE YOU DOING THIS WITH THE CAR ON?
AND IF YOU ARE DOING IT WHILE IT IS ON, MAKE SURE THE THROTTLE IS IN THE WIDE OPEN POSITION SO THAT IT CAN ACTIVATE THE MICRO SWITCH.
EMAIL ME AT adingcong@msn.com
MAYBE I CAN HELP
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
