Fog Light Switch Wiring Diagram
Old Feb 1, 2002
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I am in need of a diagram of the 2002 civic ex coupe factory fog light switch. I am trying to hook up my underbody kit without using a cheap switch. I thought that the factory look would be nice. The hard part is figuring out what pins on the switch go to where. So if anyone has any info or suggestions for me I would appreciate it. If anyone already has the kit installed and knows how to test with a multimeter could you please probe each pin for me and inform me what pin hooks up to what. thanks.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 1, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
somebody must know, i think someone used a fog light switch for something else already
Old Feb 1, 2002
toastyghosty's Avatar
toastyghosty is an unknown quantity at this point
look in the download section of this site you'll find the fog light install pdf
Old Feb 4, 2002
vipergtsr's Avatar
The Install PDF only has a diagram for the whole system not a specific switch diagram. I need to know exactly which pin is supposed to be connectd to what.
Old Feb 5, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
Viper... I did the same exact thing you are wishing to do.
I used the Honda OEM Foglight switch for my undercar neon. It took me about 15 minutes or so of playing with each lead to figure out how it all worked.
I'll try to make up a diagram of the switch, but first I need to find out how I did it again.
But after you're done, it will look really clean, like it was built in at the factory.
Old Feb 7, 2002
ph0ng's Avatar
Here it is for all you ppl who want to wire up your foglight switch custom.
Sorry for the delay, but hopfully this will help you finish the job.
Foglight Switch Diagram
**Side note**
for the switched 12v+ I tapped into the same wire on my cruse control switch... being it's all the same setup on that switch.
Good luck!
Old Feb 9, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
thanks man, you just saved me the trouble of playing around as well...ive had the stock switch for a while, but just have been too damn lazy to hook it up to my fog lights.....hehe
Exterior
Nov 28, 2025 05:23 PM
darwin-t
Apr 18, 2015 09:29 PM
AlpineCivic
111
Oct 20, 2003 07:31 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
