Question about neons
Old Feb 12, 2002
JSH2001's Avatar
JSH2001 is an unknown quantity at this point
I was planning on installing some neons under my seats pretty soon and wanted to wire them into the back of the cig lighter. I did a search and understand all of the wiring but someone had posted that the console with the cig lighter in it just pops right out but I havent had any luck popping it out. I was just hoping I could get some help with removing that to get to the back of the cig lighter. Thanks
Old Feb 12, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
Personally I think that you are better off wiring it somewhere on a open fuse terminal. I never liked hooking anything up to those wires, except for a radar detector. I just tried popping mine out but like you said it doesn't budge. you might have to take it all apart.
Old Feb 12, 2002
JSH2001's Avatar
I understand what you need to do to wire it to the backk of the cig lighter is the only reason I want to do it that way. If I new how to wire it to an open fuse terminal I would do it that way. So maybe if I could get a DIY to wire it to the fuse box that would be helpful.
Old Feb 12, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
just pops right out.....pull harder maybe or use soemthing to pry being careful not to scratch any plastic
Old Feb 12, 2002
JSH2001's Avatar
When you say cig lighter console, do you mean the whole big piece that the cig lighter is located in or just the cig lighter itself pops out.
Old Feb 12, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
check the thread for head unit (radio) removal. the part you wish to remove is one of the steps to switch cd playes. to do it the right way you disassmble the entire center console . afterthat is removed you can get behind that cig lighter panal and push it out. if your to lazy to do it the right way like me, take a small flat head screw and pry @ the corners with a rag inbetween the screw driver and all the plastic that doesn't come out.if you put a little pull and push into it she'll pop right out real quick just line up and push for the finally . the cig lighter is just a pull out harnes to make the job easier. if you dont put the rag under the screw driver you get ugly little notches all over your dash, lime me[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
good luck
Old Feb 12, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
it was hard for me to pop off but what i did was put a big A$$ screw driver (flathead) and put it behind the center peice from the front under the dash and push that out while pullin with ur fingers in the hole ( the removable piece right next to the cig lighter LOL for those who thought about it yall are perverts LOL) and push and pull HARD and it should pop off
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
