New project/A Couple Questions
Old Feb 17, 2002
CaseysGuy385's Avatar
CaseysGuy385 is an unknown quantity at this point
Hey everyone. I just finished up a Dynamat project on my 2k1 civic last night. I also wired in a GPS unit next to the cup holder. I do have a couple of questions though if anyone can help me out. I want to install a neon tube under each side of my dash and then wire them in to work as the dome light does. I found the wire (red/green and white/blue) under the dash, but I ran into a little problem. I hooked up a tester to the white/blue wire and it has power constantly. I hooked up the tester to the red/green wire, and here is what I found:
1) When the dome light switch is in the auto position and the doors are closed, the wire has power.
2) When the dome light switch is in the on position and the doors are either open or closed, the wire does not have power.
3) When the dome light switch is in the off position and the doors are either open or closed, the wire does not have power.
So here is what I am thinking; I need to get a relay that turns power on to my lights when the switch (the red/green wire) goes off. Does anyone know of a good place to get such a thing? Or maybe if there is a better way to do this? Thanks!
Old Feb 17, 2002
VNlilMAN's Avatar
The Standard One
it should be the green/red wire not the white/blue one
Old Feb 18, 2002
It is the red and green, but you will notice from what I said before that it performs exactly opposite of what I need.
Bounddyy
19
Jul 20, 2015 02:42 PM
Kyles24
Jul 16, 2015 10:14 PM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
1khilari
Jul 9, 2015 08:12 PM
