gauges
Old Feb 4, 2002
Tracie's Avatar
Tracie is an unknown quantity at this point
gauges
how do you install the speed guages.
Old Feb 4, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
oh goodness. first, you search. then, you take apart everything and prefereably with out taking off your needles, slap on your gauges. that's the gist of it
Old Feb 4, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
speed guages? you meen indiglows?
Old Feb 4, 2002
Tracie's Avatar
yes the indglow whatever, but the black wall thing that is around the gauges, i cant even get that off
Old Feb 4, 2002
nbpEMCivic's Avatar
there's like 2 or 3 screws...look for them
Old Feb 4, 2002
Tracie's Avatar
i have the two screws on top but the bottom seems as it does not want to come out
Old Feb 4, 2002
Tracie's Avatar
my friend thinks i need to take off the dash board. do i? to me that does not seem reasonable.
Old Feb 4, 2002
nbpEMCivic's Avatar
after u unscrew it...just pull like hell..it kinda pops off
Old Feb 4, 2002
01civicboi's Avatar
why do you have 2 threads going? you'll need to take off the steering column housing to make it easier
Old Feb 4, 2002
Sarvic's Avatar
Sarvic is an unknown quantity at this point
Tracie, do you have the APC SpeedGlo gauges?
Old Feb 4, 2002
Tracie's Avatar
no i have some other brand, now i got the gauges in now i need to know WHERE to connect the power wire
Old Feb 5, 2002
01civicboi's Avatar
if only newbies would use the SEARCH feature. it's quite nice.
just tap into the parking light. it's the red with black stripe or vice versa. just test it with a test light.
SEARCH!
Old Feb 5, 2002
Sarvic's Avatar
tracie, if you gimme your email address, i'll send you a doc containing multiple tips on how to install them. I'm trying to do a DIY with pics but haven't gotten around to it yet.
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Feb 5, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
look at the black part that surrounds your gauges. Then on the bottom, where it meets with the vinyl dash (to either side of the steering column), stick a small flathead screwdriver in there in pry the black part up. You should be able to hear a click. That is the clip that holds it in. Do that to both sides and pull that piece out. Then just remove the two brass screws in the cornes of your gauge housing and the black one at the top. Unclip green and blue harnesses, and the gauge housing should come right out. Now unclip the plexiglass shield from the housing, then unclip the black piece with the circles.
You should just slide your gauges over the needles. Just be careful not to bend them. It takes a little force to get them to go over, so be careful. Make sure you tape the indiglos down really good with the double-sided tape provided or your needles will stick at certain points...
I know everyone jumped on your case for not searching, but don't be discouraged. Everyone was new at some point...
Old Feb 5, 2002
Tracie's Avatar
Mokushi, thank you! i figured it out yesterday thanks though for everyones input. i attached it to the wires that connect to the top of the gauges.
Old Feb 5, 2002
Tracie's Avatar
01civicboi: there was two threads b.c. that was the first time i tried this whole asking a question thing, i just didnt totally get how the site worked. second i was searching i just was not finding it right away and i was in a hurry b'c my friend was taking my car apart and lets just say if he takes out things then when he goes to put them back in he some how always has something left over always. all is forgiven.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
