HELP: Need help, problem with car
Old Oct 12, 2003
Samari's Avatar
I have an 03 civic coupe EX. As of today i went down and when i started my car, the RPM's went up and right down to 0 and cut the car off. I started it back up and it was ideling low, around 700-900. Im not sure if that was normal but i thought it ideled around 1k. Also I drove around and when i hit the intersection my car killed due to the RPM's. I started it up again and it hasnt cut off since. The RPM's seem to idel low. Can someone let me know something. I might stop by the honda dealer if i cant figure anything out, but hopefully yall can help me out. Also will the dealer charge me to take a look at my car if?
Old Oct 12, 2003
Jodster's Avatar
Post Whore General
As long as your car is still in warranty they will not charge you. I would take it the dealership.
Old Oct 12, 2003
my car is still under warranty, and they were gonna charge me 40 bucks to have them inspect my brakes.. damn bastards...
you mite wanna call in toyou dealership and see if they'll charge you or what..
Old Oct 12, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
my car normally idles at 750. After I put my intake on, it's more like 700, but still good.
Old Oct 12, 2003
Samari's Avatar
okay, maybe its normal then. but i dont know why it was cutting off.
Old Oct 12, 2003
clownprince's Avatar
Ricerus Maximus
Menikie has free brake inspections. As far as it cutting off, take it to Honda and tell them to look at it. It could be something simple that they could fix in 10 minutes, or it could be something that could disable your car later down the road.
Old Oct 12, 2003
jwalker87's Avatar
Bodacious Member
id say his car shutting off is pretty disabling already
Old Oct 12, 2003
Connie's Avatar
Mine idles around 900 but the cutting out is weird, my car has never done that. I would ask your dealership...
Old Oct 12, 2003
jwalker87's Avatar
Bodacious Member
there was a really long thread on this before, too. I think the answer is in there; some part that went bad. Search for it.
Old Oct 12, 2003
streetglower's Avatar
most dealerships will charge to look at brakes since they are really only covered under a 1-3 month warranty and are normal wear and tear parts, but it all depends on what is causing it to cut off, it might be a worn out part, honda usually charges to look at your car, but if you get work done their, they take off the charge to look at your car.
Old Oct 12, 2003
Samari's Avatar
i saw the thread. i just resetted my ECU and the car seems to not do it anymore. hopefully it will stay this way. im a little relieved
Old Oct 14, 2003
Samari's Avatar
okay, the ecu did not work. i scheduled an appointment with my honda dealership for friday so i will let yall know whats up. i told them that many people have been having this problem and if they fix it i will let yall know what they did.
Xuhme
21
Aug 7, 2023 03:40 PM
Tedverseti
Apr 23, 2020 01:45 PM
tylerginevan
Apr 27, 2015 12:29 PM
McD
Apr 16, 2015 10:46 AM
dooner24
Apr 14, 2015 07:51 PM
