Headlight Clearing Question
Old Sep 15, 2003
C-Loak's Avatar
New Member
C-Loak is an unknown quantity at this point
Question Headlight Clearing Question
I read the DIY about headlight clearing and it just stops after the headlight is disassembled. I just want to know the correct way to re-assemble it and what kind of sealant to use when I put it back together. I really want to do it right so I get a good seal and no condensation will occur.
Old Sep 15, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
i've must've posted 100 times on this, I know you're new, but S E A R C H....anyways, use the best kitchen / bath sealant you can find and use alot.
Old Sep 15, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Just put it back together the way you took it apart. Reverse directions.
Old Sep 15, 2003
civicvtec1ps's Avatar
Search and Learn
yea not hard,
Just go buy clear silicon make sure you cover everywhere so headlights wont fog
Old Sep 15, 2003
FALKEN's Avatar
Civicforums Junkie
simply just reverse the disassembly process...
take your time and look at what your doing and it wont be hard at all
FOR SEALING:
GE Kitchen & Bath Silicone II Sealant
2.8oz. tube
CLEAR
Home-Depot...$2.97
FOR PAINTING:
'High-Heat' spray-paint
BLACK
Home-Depot...$3.94
*no prep needed, just sprayed it*
Old Sep 15, 2003
C-Loak's Avatar
New Member
Thumbs up
Thanks, I'll have some blacked out lights thanks to you guys.
Old Sep 15, 2003
BREEZE's Avatar
Yeah, i drive an EP
BREEZE is an unknown quantity at this point
you dont even have to buy anything just use a heat gun or something and heat up the tar/goo and press together and it will stay just like like dat
Old Sep 15, 2003
Mox's Avatar
Mox
Mox is an unknown quantity at this point
I didn't use anything to re-seal it...there was enough factory sealant left to just press it back to geather(will take a little muscle). I have had mine done for about 3 months now and I havn't had any problems with condensation yet.
Old Sep 15, 2003
tripledoublegs's Avatar
Euro-Spec
I did it on my friend's car and by morning the headlight was all foggy and s**t. I'm not doing it on mine. I'll save up and buy the real blacked out ones.
Old Sep 15, 2003
SEALING
Just pop both halves back in the oven and let the goo soften. Squeeze them back together and let dry. Easy. I've never had any problems. You may want to borrow some of the goo to hold the reflector in place or it will be loose.
Old Sep 15, 2003
doctorfeelgood's Avatar
doctorfeelgood is an unknown quantity at this point
MAKE SURE YOU SEAL THAT **** UP GOOD.... i cleared mine and they are fogged up like a mother****er every morning
Old Sep 15, 2003
sometimes mine fog up in the mornings now that I'm living in a humid area. It's the sockets that are most likely the problem-they're just screw on.
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Ccoop87
Jul 9, 2015 03:26 PM
BootyDo
Jul 7, 2015 06:06 AM
BR549
Jun 25, 2015 04:03 PM
carid
Jun 16, 2015 06:40 AM
