kms install question
Old Sep 16, 2003
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
what did you guys do to the hose that came from the block to the stock manifold?
Old Sep 16, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
the PCV? run it into the manifold.. if not then oil catch can? i duno thats just MO .. but thats for turbo set up
Old Sep 16, 2003
i think its just a vacume line or a breather line. im not really sure. but when i took out the old manifold it was attached on there. now there isnt any place to put it on the new manifold.
Old Sep 16, 2003
djmota's Avatar
its a breather line. you can just put one of those little breather filters on it
Old Sep 16, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
That's what I did...It will be fine
Old Sep 16, 2003
so hows ur cars running. did you guys get your cars tunned? how is it running?
Old Sep 17, 2003
cwick187's Avatar
I never tuned my car because I ordered the VAFC 2...When it comes in, I will be tuning it with the AEM Cam gear.
Old Sep 17, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
where did you get a manifold? why did you get a new manifold? aftermarket? aluminium or plastic composite?
Old Sep 17, 2003
civic-king's Avatar
i posted this (breather filter) as a "useless wasted money mod" yesterday.
small amounts of oil travel through that line, to lube up the throttle body. if you cut that line off, by adding a breather filter, you cut off that lube, and your throttle body might seize up, then you punch the gas, and your result is a chipped, or cracked throttle plate. (this takes many miles, but it will happen) also, that hose helps to warm the engine on cold starts.
the seventh gen. civic has no pcv. the technology has moved up. (i looked everywhere, wanted to put the GP2000a on my car)
Old Sep 17, 2003
djmota's Avatar
on the 7th gen there are 2 breather outlets one on the valve cover which you are talking about amd one off of the crankcase, which we are talking about. the one on the crankcase is soley there for reburning vapors in the case.
Old Sep 17, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
yup one on valve cover is a breather port... the one on the head is OUR PCV. and if we have no PCV.. explain where us turbo cars hook up our catch cans?
Old Sep 17, 2003
civic-king's Avatar
where at on the head? that's vary interesting......
Old Sep 17, 2003
civic-king's Avatar
i went for a gander at my engine, and could find NO pcv valve....?
where is it?
i found a vent, but it has no hose that goes to the plentum.....
vtecbrah
May 31, 2015 01:24 PM
One_PeeJay
May 17, 2015 05:31 PM
ywgflyer
May 15, 2015 05:05 PM
edgenet
May 2, 2015 08:00 PM
Dorval Andre
Apr 20, 2015 05:34 PM
