Quick 12v question
Old Oct 4, 2003
Big Baller L's Avatar
Nugget Garage Since 2004
Question Quick 12v question
I'm trying to install my air/fuel guage, and ive read the diy by boilermaker. My question is Where is another 12 volt source that I can tap into for power. The cigarette lighter is already been tapped for my voltmeter, so I need an alternative. Also what does 12 volt equal in amps? Thanks
Old Oct 4, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Under the menu on the right click on Vehicle wiring database...
you'll find extra 12V there
http://www.7thgencivic.com/modules.p...ase&file=index
You'd have to know what the resistance is to find out the actuall
amps on the wire you want to hook up too.
Use OHM's law to figure it out
I=R*V
or P=I*V
Old Oct 4, 2003
lowblue02's Avatar
lowblue02 is an unknown quantity at this point
There is a 12v behind your radio but I dont think that is where you want to tap in to. There is another on under the stearing wheel but I am not sure of the color.
Old Oct 5, 2003
^^yah i read about those two but i cant find the one under the steering wheel, and i dont wanna mess anything up thats in there. I havent looked behind the radio, but if i have an aftermarket HU would it sill be there?
Old Oct 5, 2003
skipbarber's Avatar
yes it would still be there, but it would probably draw to much current and blow a fuse. just use your accessory wire in your steering column. once you remove the steering column shroud you'll see all the exposed wires, look under the key cylinder and look for a large brown plug with the thick gauge wires, (the only thick wires are the one in this plug) i believe its a six pin harness. you don't want to use constant 12v because the gauge will never turn off completely where as accessory only runs with the key.
Old Oct 5, 2003
^^okay i though that the thick wire was a completely different harness. I figured the thicker the wire the more power it would produce, but i forgot that the amount of power depends on its source. So if i tap into the white wire in that harness than it should be okay?
rman1900
21
Sep 10, 2018 04:52 PM
Strycker
Aug 2, 2015 08:40 PM
sch2cm
Jul 21, 2015 09:58 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
