Which way does the coolant run through the radiator?
Old Oct 2, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Is the top hose out of the engine and the bottom hose into the engine?
I'm just assuming since the bottom hose connection has an electrical plug in the block next to it, which I assume is the thermostat.
Anyone know for sure?
Old Oct 3, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
well i would think it would go from top down.. just because its the easiest way to cycle the coolant...
Old Oct 3, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
bottom goes into the engine via water pump...pumped up and out the top through the thermostat when it gets hot enough for the thermostat to warm up.
You can feel when it opens up and you can see it if you start the car from a cold
start and watch the engine temp gauge. You will see it jump just below midway.
good luck
thana
Jun 15, 2020 07:05 PM
danace99
23
Jun 28, 2015 08:49 AM
zaboomafoozarg
May 30, 2015 09:21 AM
deus-ex
Apr 13, 2015 12:29 PM
RallyEX
Jan 24, 2002 11:12 AM
