Oil Change Question
Old Oct 15, 2002
Black02's Avatar
Black02 is an unknown quantity at this point
Oil Change Question
I'm about to change my oil for the first time and had a quick question I couldn't find using a search. When the owner's manual says to add 3.7 quarts of oil, how does everyone measure the 3.7 quarts of oil? I bought 4 quarts and i'm hesitant about pouring all 4 quarts in because I have heard its bad to have too much oil. Any advice would be helpful. Thanks
Old Oct 15, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
you can guestimate can't ya? btw, that's what a dipstick is for [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Oct 15, 2002
RedDragon333's Avatar
pour all of the three and then pour a little of the next Qt in then when you think its enough turn on the car let it run for a few mins then check the oil status and see if you need to add a little more and continue process until your good to go...it shouldnt take more than a few times
Old Oct 15, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
There is usually a sight strip on the side of the oil container. Pour in 3 whole quarts. then start pouring in the 4th. Pour in most of it, and start watching the oil line in the clear strip (you have to hold the bottle upright to check) Mobil 1 bottles measure in .250 L increments (see photo). I poured in a little less than 3/4 of the last bottle, and that was just about right.
Old Oct 15, 2002
Youthachak's Avatar
Youthachak is an unknown quantity at this point
What are the effects of putting 4 quarts in[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]Because i've did a total of 3 oil change and put 4quarts of oil in all of the time.
Old Oct 15, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
four quarts arent going to hurt your car.....just try to put the right amount in from now on
Old Oct 15, 2002
Black02's Avatar
Thanks for the help and quick responses. Also, Boilermaker1 thanks for the picture, thats the same oil i'm using. How do you like the Mobil 1 oil? Thanks again.
Old Oct 15, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
what would happen if you put 5quarts?
Old Oct 15, 2002
Jap-Euro Fusion
Quote
[hr]Originally posted by: Notorious
Thanks for the help and quick responses. Also, Boilermaker1 thanks for the picture, thats the same oil i'm using. How do you like the Mobil 1 oil? Thanks again.[hr]
It's been in the car for 4 days, I don't know any long term comments.... But it is showing up a little cooler on the temp gauge. So I guess it's working. The car does idle a little smoother, but it was smooth to start with, so it's not much improvement. I hope this stuff will be a bit more consistent and last longer than the Honda junk, 10000 mile oil intervals my ***, it went 4300, and it was bad.
5 quarts and you'd probably be spilling oil into places that you don't want it to be. I wouldn't do that.
Old Oct 15, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Quote
[hr]Originally posted by: civichx81
what would happen if you put 5quarts?[hr]
You would actually be beating your oil into foaming. Foam doesn't lubricate very well because of the high air content and you will end up killing your engine from thermal wear. Don't do it.
4 qts won't really hurt, I put 3.5 in mine and it's fine. It seems to be a little over the mark everytime, maybe just a hair.
Old Oct 15, 2002
DxMaN's Avatar
DxMaN is an unknown quantity at this point
Is it just me, or does oil filter = mess. Honda had to put that b!tch on horizontal so you have almost no choice but to spill some. Even on ramps, with the oil filter tilted slightly, I still get some decent spillage. You also have to snake your arm around the suspension so it's tough to get a paper towel ready.
Any tips?
Old Oct 16, 2002
1955's Avatar
70% of 32 ounces is just over 21 ounces,just leave about 11 oz in the bottle and u will be fine.
Old Oct 16, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Don't forget to put a little in your filter before you put it back on...[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
mrohitredd
May 28, 2015 10:03 AM
BootyDo
May 7, 2015 04:46 PM
Grazzhopper
Nov 11, 2001 08:06 AM
