remote start for civic?
Old Oct 22, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
is there a way to get around the chip in the key so a remote start can be used???
Old Oct 22, 2002
FALKEN's Avatar
Civicforums Junkie
Is it really that hard to turn your key by hand??
Old Oct 22, 2002
skc's Avatar
skc
skc is an unknown quantity at this point
Installing An S2000 Engine Start Button
hope it might help.
edit: oops[IMG]i/expressions/face-icon-small-frown.gif[/IMG] i misunderstand ur question. didn't read it carefully.
Old Oct 22, 2002
YS's Avatar
YS
YS is an unknown quantity at this point
when i baught an aftermarket alarm, they put my OEM key (w/ chip) into a black box( i forgot the brand name). The box used to read the chip in the OEM Key, so you can install a remote start. and after that, you can use any after market key (w/o Chip) for 7thgen civic.
i'll check out the brand name for the chip reader A.S.A.P
Old Oct 22, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
There is a thing... its like a ring that fits under the dash that overrides it... thats how you can start the car without the chip being recognized
I think it's an addon made for specific vehicles and costs like $20-30
Old Oct 22, 2002
Gizmo's Avatar
Gizmo is an unknown quantity at this point
Yeah theres ways to get around it. However, why would you want to disable the one thing that makes our cars harder to steal?
Old Oct 22, 2002
WhiteRabbit's Avatar
check your DIY's.....
Old Oct 24, 2002
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
Temporary Bypass Ignition Immobilizer Without Cutting A Key
PKH3 is designed to temporarily bypass select Honda/Acura ignition immobilizer systems (Click Compatibility Chart for vehicle listing) when remote starting.
If installing remote start on a vehicle that is not on the compatibility list below then verify if the GREEN plug coming from the transponder ring from around the ignition cylinder has "7" wires, if it does then the PKH3 should work on the vehicle.
The transponder immobilizer systems found on the listed Honda and the Acura vehicles can be temporarily disarmed with the use of a PKH3 transponder interface kit. Most Importantly, the PKH3 is a "No Key Required" Bypass, once this Transponder Bypass Kit is programmed "ALL" the original vehicle keys are returned to the owner. Adding a remote starter to any of the listed vehicles does not mean you have to give up one of the costly transponder keys, plus the PKH3 is more reliable and secure than the key in the box type bypass kits.
carhag2000
Apr 25, 2015 01:33 PM
Linda0818
Apr 23, 2015 11:30 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
