Custom sub box help
Old Oct 16, 2002
shanebrakeman's Avatar
shanebrakeman is an unknown quantity at this point
Custom sub box help
I'm building the custom sub box off of 2k1civic. How would you wire the wires to the speakers?? Cut a hole in the bottom off eac encloser???link here And for the people that have done this before What is there any tips you can give me?
Old Oct 16, 2002
Lightman's Avatar
Lightman is an unknown quantity at this point
i drilled a hole just big enought to fit the wires through.
Old Oct 16, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
What I did is drilled a hole the same size as my speaker wire. I use 8 gauge just for the hell of it. then the speaker wire will already be tight in the hole, just seal it good with some silicone or some type of caulk. Next post in the ICE forum to get more help.... Good luck with that enclosure, I'm thinking of building one similar too....
Old Oct 16, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Fixed Linky
Well, you could do that or you could just get gromets and make sure no air escapes where the wires come in.
You can also get those connectors, like the back of sub boxes have, and put them on the outside then run the wires from the inside to the speakers. Do you know what I'm talking about?
Old Oct 16, 2002
IDQcivic's Avatar
Done mess with those connector things, just run the wires directly from the sub (which you should solder to the terminals) to the amp and use some crimp terminals at the amp for a good connection. Its not like your gunna have to disconnect the box, if you have to cut the wire there is more chance something can go wrong, its better to have 1 cable with a direct path.
h4ldol
Apr 24, 2017 08:16 PM
Raiool
Oct 1, 2015 10:42 AM
Hutch1051
Sep 29, 2015 09:20 AM
carid
Sep 28, 2015 10:13 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
