Can Someone Explain Gear Ratios?
Old Nov 4, 2002
artychris's Avatar
artychris is an unknown quantity at this point
I ran a search on gear ratios and all I got was the difference between the LX and EX.
I'm curious on how to translate those numbers into how it affects acceleration and top speed.
If possible, can one draw a diagram so that I can have a visual?
Many thanks in advance, I crave the knowledge and unfortunately I am in the dark on this one.
Old Nov 5, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
its real simple
say the gear ratio is 4:1.....every time the engine turns 4 times, the wheel turns once (obviously this is extremly simplified)..but you get the idea
it the gear ratio is shorter, such as 4:1, as oppsed to 1:1, the car will accelerate quicker in that gear......like any "overdrive" gear is a gear w/ a ratio lower then 1:1, such as .98:1 is considered an overdrive....
too tired to keep rambling random information, im going to bed
mark
Old Nov 5, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Can you explain final drive while you're at it? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 5, 2002
CivicManDan2's Avatar
CivicManDan2 is an unknown quantity at this point
i need a new transmission. i have a DX but all i can find in the junk yards are the EX. if i used this tranny do u think it would be a problem stock? would it hold a benefit with a nitrous oxide or turbo set up?
Old Nov 5, 2002
Atlantis's Avatar
Atlantis is an unknown quantity at this point
A quick note: The gear ratios for the manual trans are the same for the DX as the LX. The auto trans is the same for ALL models except the final reduction.
Old Nov 5, 2002
astr033's Avatar
astr033 is an unknown quantity at this point
Check out: How Gear Ratios Work
I love that website. It shows you how a lot of stuff works.
Old Nov 5, 2002
astr033's Avatar
Quote
[hr]Originally posted by: mwwhonda
it the gear ratio is shorter, such as 4:1, as oppsed to 1:1, the car will accelerate quicker in that gear.[hr]
The final gear ratio for my HX CVT is 5.810. So what the heck does that mean? Does this mean my car will accelerate quicker?
Old Nov 5, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
It means, once you're up to speed, you won't have to press down on the gas as hard to maintain the speed you're going.
Old Nov 5, 2002
HondaGuru's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
HondaGuru is an unknown quantity at this point
http://www.howstuffworks.com/gear-ratio.htm is good.
This is a bit simpler:
http://www.msgroup.org/TIP094.html
Old Nov 5, 2002
HondaGuru's Avatar
edit: didnt see how stuff works already posted.
nirvanaguy
25
Oct 26, 2017 07:26 PM
Whitexj
Sep 30, 2015 02:04 AM
BBrosario
Sep 17, 2015 07:51 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
NROD315
Sep 4, 2015 09:22 PM
