Reverse Indiglo Gauge question?
Old Oct 28, 2002
Hawk's Avatar
You boost, I-VTEC
ok i just bought reverse indiglo gauges and i was looking at the diy and i have a question.
This parts marked "here" am i suposded to cut it or something? cause in this pic below it looks like they were cut out.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
thanks for the help
Old Oct 28, 2002
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Mine were cut like that when I got them...though mine were for a manual...You should cut them because you have your High Beam Light, Cruise Control, and Check Engine light behind those....probably seat belt light as well.
Matt
Old Oct 28, 2002
Hawk's Avatar
You boost, I-VTEC
so do you know if its safe to cut that part off?
Old Oct 28, 2002
Black02's Avatar
Black02 is an unknown quantity at this point
Hey Hawk, I just got my reverse indiglo gauges in the mail today and they look exactly like yours. Same brand and all. Mine also not cut around the edges like yours. You definitley brought up a good question. But for some reason, I don't think they are supposed to be cut out. Also, does your blue/green switch look like a flat thin piece of wire? The switch seems kind of cheesy in my opinion. Anyway, hope someone here has an answer.
Old Oct 28, 2002
Hawk's Avatar
You boost, I-VTEC
yeah the switch is quite cheesey im gonna hide mine where the diy shows it.
Old Oct 29, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Yes you have to cut them.... Just get an exacto-knife or razor and trace around the edges so it looks like the DIY, and your gonna have to notch out the clear plastic on both sides so it will fit the 2 wires coming down. Good Luck gettin em on, they're are tough little devils to snake on. Oh and like it says too, be sure and secure them down with some double-sided tape or something so they don't stick your gauges..
That's what i did
Old Oct 29, 2002
Hawk's Avatar
You boost, I-VTEC
thanks for the help
Old Oct 29, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Yeah, just use the black trim piece from the gauge cluster and outline the area you want to cut out. Just cut out the white parts and try not cutting into the off-white part. Also, dont cut off too much else you'll get a gap between the trim piece and the new gauge face (old face will be exposed).
Hope that made sence. [IMG]i/expressions/laugh2.gif[/IMG]
-Kre
Old Oct 29, 2002
Hawk's Avatar
You boost, I-VTEC
Quote
[hr]Originally posted by: Krepoort
-Kre[hr]
made enough sence as to wear i understood it.
Thanks for the help
Old Oct 29, 2002
Black02's Avatar
While on the topic of indiglo gauges, does anyone know if you can just ground the black wire from the indiglo gauges to the all black wire on the factory wiring harness? This seems like a better place to ground the indiglo gauge wire. Thanks
Old Oct 29, 2002
JDanMCivic's Avatar
JDanMCivic is an unknown quantity at this point
Where can you get just a white face gauge. I have a coupe and I like my orange/red lights, I just dont like the gray face gauge, can I find something white, and clear so the the orange light will go through or something?
MacLifeBrand@aol.com
15EXCoupe
Jul 30, 2015 12:59 PM
Kyles24
Jul 16, 2015 10:14 PM
Yazan93
Jul 14, 2015 08:56 PM
Kyles24
Jul 12, 2015 09:15 PM
