Nasty Rattles
Old Nov 2, 2002
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
Nasty Rattles
I have a 12 inch fosgate, in the back, and im getting a rattle near my passenger door side. It is coming mostly from the area of the seatbelt connects to the B pillar. Has anyone else had this problem? And is there a simple way to fix. I usually don't care about rattles, but when it is inside the cabin, it starts to bother me. I have tried to move the sub around in my trunk for different setup but it just will not go away.
Old Nov 2, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
I have the same problem as you do and I want to fix it
Somebody help us!
Old Nov 2, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
same problem!!!!its so bad now even if i turn off the subs but speakers on full i hear the rattle
Old Nov 2, 2002
dragoon's Avatar
this is why i'm putting sound deading under every single interior panel.
Old Nov 2, 2002
BlueRevs's Avatar
Quote
[hr]Originally posted by: dragoon
this is why i'm putting sound deading under every single interior panel.[hr]
Isn't that kind of a pain
Old Nov 2, 2002
VTEC808's Avatar
VTEC808 is an unknown quantity at this point
Anytime you put a significant amount of bass in a car its gonna cause rattles & the rattles will get worse as time goes on. The bass is loosening things up over time & after they are loosened, even without anymore bass, it will get worse. When you put subs in a car you HAVE to continually check all your bolts & retighten them as needed. Thats the ONLY way to eliminate rattles caused by the subs. I have gone through that for 7-8 years.
Dynamat will help, but it won't totally eliminate the problem.
Old Nov 2, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
man i have that same NOISE.... it sounds like someones taping their fingernail on the plastic.... usually if i lean accross the car and push against the door that will stop it for like a second... im about to twist out the rubber stoppers to make the door close tighter....
Old Nov 2, 2002
dragoon's Avatar
Quote
[hr]Originally posted by: BlueRevs
Quote
Isn't that kind of a pain[hr]
yes, but it solves everything.
Old Nov 2, 2002
smpcivic's Avatar
smpcivic is an unknown quantity at this point
I had my whole interior appart one day i mean whole thing....all you saw was the bare frame from the doors back...i put dynamat all aorund and closed it all back up....didnt do a damn thing!!!! i give up
mistahlorax13
21
Nov 18, 2015 12:47 PM
rovafa2002
Sep 28, 2015 06:57 PM
fvckbg
Sep 8, 2015 09:55 PM
dantheman42
Sep 4, 2015 01:10 PM
Yazan93
Jul 14, 2015 08:56 PM
