easy upgrade
Old Oct 14, 2002
saqib's Avatar
saqib is an unknown quantity at this point
easy upgrade
i heard that there is no way to simply install an intake or exhaust in the 7th gen civic. something about the computer not funtioned to allow more fuel in. do you have to buy a vtec controller or whatever?
Old Oct 14, 2002
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
You heard some BS. You can easily put and intake and exhaust on our Civics without ECU upgrades.
Old Oct 14, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Quote
[hr]Originally posted by: saqib
i heard that there is no way to simply install an intake or exhaust in the 7th gen civic. something about the computer not funtioned to allow more fuel in. do you have to buy a vtec controller or whatever?[hr]
What does more fuel have to do with VTEC? Someone's giving you the run around. I'm guessing they're talking about the V-AFC which controls the air/fuel mix and can control VTEC.
But to answer the question, you can put them on, it's a simple swap of stock parts for aftermarket stuff, but you won't see a whole lot of power from it. Install the intake, reset the ECU, and off you go. I'm not sure about the exhaust. As long as the O2 sensors are still hooked up (or an O2 sim if you need it), there's no problem.
Old Oct 14, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
dunno what that person is smoking, but its easy to put on intake and exhaust, just have to reset ecu if u dont wanna wait it'll reset itself
Old Oct 14, 2002
XxJDMCivicxX's Avatar
ya u dont have to reset your ecu only if you want to cuz when i installed my intake I didnt have to reset it or anything just gotta fix your clock and your radio stations [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Oct 14, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
i think 1 individual person's answer to this question is sufficient. we dont need 5 replies all stating the same damn answer...
Old Oct 14, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
Resetting your ecu you can use the 15amp fuse labelled "F.I ECU" which will keep your radio settings and not set off your lojack [IMG]i/expressions/face-icon-small-smile.gif[/IMG] as for the V-AFC it is useless unless you have done serious mod's such as a cam/springs which you will need to go to a dyno to tune the air/fuel ratio...Same for the Vtec controller there is no need for that unless you have a cam or a significant amount of HP gains, You can change your Vtec crossover to whatever you want but it should be where the HP and Torque cross which would need a dyno =).
Old Oct 15, 2002
saqib's Avatar
so what does resetting the ecu do and how do you do it? and a header wouldnt need anything major either would it? thanks.
Old Oct 15, 2002
DarkCivic's Avatar
To reset the ECU, unhook the negative battery cable for 10 mins, then reconnect. When your car is disconnected for that long the ECU has to reset itself. It does this by reading the air/fuel ratios which will be different with and intake. You should do this with any mod that affects your engine, including adding a header.
Old Oct 15, 2002
xblkcivicx's Avatar
Quote
so what does resetting the ecu do and how do you do it? and a header wouldnt need anything major either would it? thanks.[hr]
Resetting the ECU will allow it to "learn" and adjust your air/fuel ratio accordingly, such as an intake would be inducting more air which would need more fuel. The ECU will learn over time, but for the time it takes it will not run properly. to reset your ECU I recommend (if you have a radio with presets) opening your fuse box and pull the fuse labeled "F.I ECU" (Fuel Injection ECU) its a 15A fuse, pull this for about a minute (per Senior tech at Acura) I pull mine before starting the mod. After putting it back in start your car and DONT TOUCH THE GAS for 10 minutes you'll see your idle jumping around, turn off, on, off, on and your good to go.. and yes you would need to do this after installing a header.
Cam Diaz
Sep 29, 2015 07:17 PM
meicalnissyen
Sep 25, 2015 12:12 AM
AffliictiioN
Sep 16, 2015 02:21 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
