What does a vaccuum gauge do?
Old Oct 27, 2003
IronFist's Avatar
I saw one at the meet but I've never heard of it before. What does it measure?
Old Oct 27, 2003
civicvtec1ps's Avatar
Search and Learn
A vacume gauge can be connected to your intake manifold to measure the amount of vacume that your engine is drawing. By monitoring the intake manifold's vacume level you are monitoring how much fuel your engine is using as well as how hard your engine and cooling system is working.
If you're going up a hill under full throttle your vacume gauge will read close to zero. What this tells you is that you're using a lot of fuel, and the engine is really having to work hard and is producing a lot of heat.
If you shift to a lower gear, the vacume gauge will read a higher vacume. This tells you that you are not using nearly as much fuel as you were in the higher gear, and you're engine is having a much easier time maintaining the rpm. Your engine is generating less heat for your cooling system to dissipate and the the load on things like connecting rod and crankshaft bearings is less.
Under normal highway driving conditions you can use the vacume gauge to set your speed and select gearing to provide better fuel economy and to ease the strain on your cooling systems during hot days
power of search
Old Oct 27, 2003
IronFist's Avatar
Cool. Thanks. Are they hard to install? I'm not gonna add any gauges but that sounds cool.
Old Oct 28, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
hey I need one of those because where I live everything is like 45 minutes to an hour away.....Where can I find one??????
Old Oct 28, 2003
Looney_01Civic's Avatar
Looney_01Civic is an unknown quantity at this point
I bet you could find one at a parts store or something.... Maybe try autometer or other gauge makers websites.
Old Oct 28, 2003
DroppIN808's Avatar
DroppIN808 is an unknown quantity at this point
ooh i learned something new today besides security issues on UNIX at class =)
Old Oct 29, 2003
Got Boost???'s Avatar
Just think of vaccuum as the opposite of boost.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
