Kamikaze install problems
Old Oct 24, 2003
CelCUs's Avatar
CelCUs is an unknown quantity at this point
Hey i got my kamikaze headers for DX/LX yesterday and started installing them earlier today when i ran across a problem.
Taking the header off was easy enough to figure out, hooking up the MIL Eliminator and soldering the wires was as well but when i put the kamikaze on i realized that the "nuts" that hold in the 2 screws that connect the exhaust to the header are welded onto the old header.
Am i doing something wrong or am i supposed to go out and buy some screws? Anyone know what size i should get?
And yes i did search, i can't find anything on kamikaze installation. But feel free to make me look stupid and send me a relevant link though, i really just wanna get my car off the blocks in my garage.
Old Oct 25, 2003
CelCUs's Avatar
Not a single person had this problem ???
My car must be "special".
Old Oct 25, 2003
acidbaby's Avatar
The Beez Kneez
no there is nothing wrong, the old header didnt have threads on the bottom of it because of the nuts. the new header is way thicker and
it is threaded. i was wondering the same thing for a while until i looked at a friends car and wada ya know the same thing. so no big deal, i guess you could get a bolt for looks but you dont acctually need it. if you really look the space that the nut on the old header covers on the screw, is about the same width as the new header got without it!
but i have an ex so someone correct me if im wrong
Old Oct 25, 2003
CelCUs's Avatar
BLARG !!!
I designed my own intricate system of nuts and washers but it's leaking a lil' exhaust down at the header and exhaust connection so ima just go get it welded when i get a chance.
Old Oct 25, 2003
CapYoda's Avatar
Escaped Convict
the kamikaze didn't come with a threaded hole for u to put the bolt with spring in it?
thats pretty gay.
Old Oct 26, 2003
CelCUs's Avatar
Damnit my Check Engine Light came on last night when i was driving home from a party . . . could it be from the exhaust leak?
Old Oct 26, 2003
CapYoda's Avatar
Escaped Convict
ummmm... might not be.
i thought MIL doesnt work on ours.. u gotta get o2 simulators. but eh I'm not sure on that.
i dont see how exhaust leak will trigger the sensor.. since both are before the leak point...
unless u got a hx, there's 2 more after that.. but...
Old Oct 26, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I have the kamikaze header on my car ... no CEL ... the mil eliminator works just fine and there is no exhaust leak, from what I can tell. I didn't solder the mil elim., though ... I just used butt connectors
Old Oct 26, 2003
CelCUs's Avatar
http://www.7thgencivic.com/memberrid...cat=500&page=1
If you look at that pic you can see where the header connects to the exhaust . . . that nut on the top isn't there cuz it's welded to my stock header. Thats why i'm having the leak.
And i am probably gonna check the wires again on the simulator to make sure it's on right.
Old Oct 26, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
i have it, i went to honda and had them give me some nuts that will fix the spring loaded bolts, my MIL eliminator works perfect, no CEL after about 10,000 miles, you need a 2 inch donut gasket to keep it from leading exhaust, and you need the bolts for the LX, to make it a tight connection so you dont have a leak!
Old Oct 26, 2003
CapYoda's Avatar
Escaped Convict
wait what the. u got the EX but u're using DX/LX header??
or do you have a HX??
Old Oct 26, 2003
CelCUs's Avatar
Civic Racer 5 you are a god !!!
That was exactly what i was looking for when i asked for help. Ima swing by honda tomorrow and pick up those bolts and the gasket. Thanks a million
Old Oct 27, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
T_T;; you could've just gone to the hardware store for bolts
as far as the gasket goes ... you could just take off the one from your stock header
Old Oct 27, 2003
CelCUs's Avatar
They didn't have em' at home depot, ace hardware or lowe's. The nut is 8mm 1.25 and every nut they have in that size is too small in diameter for the hole on the header. Once you start to torque it down it just slips through that hole.
Old Oct 27, 2003
CelCUs's Avatar
Allright it was because my old gasket was a POS . . . it was all ripped apart, probably from when i installed the new kamikaze.
I think the CEL came on because the sensor was loose but how do i reset it?
Old Oct 27, 2003
the stock gasket is to small. You need a 2 inch donut gasket, you can get it at any pep boys or automotive place, the bolts i couldnt find at a hardware store either, the guy at the honda dealership gave them to me for free. My CEL works fine, just look over the diagram and make sure you have everything connected right. Disconnect your battery for like 10 minutes, and then turn your car on and let it idle for about 5 minutes without touching anything and it will reset your ECU and you CEL.
Old Oct 27, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
*shrug* ... I used my stock gasket and it works fine
4 banger
Jun 5, 2015 01:44 AM
beveragemp
May 25, 2015 07:11 PM
Youshoe
May 22, 2015 09:36 PM
PimpBot5000
Nov 26, 2001 07:15 PM
Flatlander
Nov 16, 2001 05:38 PM
