change spark plugs? Pic
Old Nov 14, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
30K miles already, i'm going to change my stock spark plugs to Denso Iridium IK20 this weekend, anythin i needs to watch up for? also i'm going to get the torque adjustable lbs wrench to tighten these plugs up to 13lbs.
anythin i needs to know, pls post up, thanks
oky, i digi some pic after i changed spark plugs to Denso.
ALL 4 stock NGK looks real bad after 30k miles, compared to Denso.....engine felt more strong now.....
Old Nov 14, 2003
djmota's Avatar
nope... pretty straight forward job. just dont drop anything in the engine, and use a magnet or the ignition coil to get the plug out of the hole.
Old Nov 14, 2003
MIT's Avatar
MIT
all right, thanks
Old Nov 14, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
is replacing the spark plugs mainly just maintinence, or is it an effective upgrade?
Old Nov 14, 2003
tuffy7's Avatar
tuffy7 is an unknown quantity at this point
Lightbulb
hot tip: use anti-seize on the plug threads.
you can buy same at any parts house
Old Nov 14, 2003
It's mostly for maintenance. You'll feel a difference if your old plugs are bad. You need new plugs for a turbo setup, though.
Old Nov 14, 2003
Bellz's Avatar
My Spark Plug DIY is on the DX-R site in my sig. All the DIYs I'm putting on there are in pdf form, so you can save it and print it out. Lots of good info there and even a FAQ.
Old Nov 14, 2003
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
A few things to keep in mind:
1. Do the work on a cold engine.
2. Use anti-seize.
3. Torque them to 13 lbs.
Old Nov 15, 2003
MIT's Avatar
MIT
Great Helps~ thanks all of you, thanks Bellz (DIY's)
Old Nov 15, 2003
hoho's Avatar
hoho is an unknown quantity at this point
what's anti sieze?
Old Nov 15, 2003
It's a silver colored liquid/goo that's used in the assembly of parts that will need to replaced in the future.
Without anti-seize, over time these parts can become "bonded" with their seating hosts making it difficult to remove thus leading to lots of cussing, swearing, possible broken parts and lost wrenches in the shrubs or other inaccesible places. The prime examples are spark plugs, water pump bolts, head bolts, or intake/exhausts manifold studs.
It also has some anti-corrosion properties making it ideal for the screws that attach the rear license plate. The screws holes are a rust magnet.
Old Nov 16, 2003
odie's Avatar
odie is an unknown quantity at this point
aren't you worried that the anti-seize could get into your engine?
Old Nov 16, 2003
MIT's Avatar
MIT
i didnt put any anti-seize stuff on spark plug, dont wanna that stuff get into engine.
Old Nov 16, 2003
lol, that's why I didn't use it. The stock plugs didn't have any. Hey--my plugs looked like that after only 18K miles!
Old Nov 16, 2003
Da1lyDr1ver's Avatar
you're not supposed to squirt a ton of antiseize onto the plugs, just a little and apply it around the threads of the plug. its a really good thing to do like Flashlightboy said, you wouldnt want any stripped thread holes where you spark plugs go now do you???
Old Nov 17, 2003
player's Avatar
Re: change spark plugs? Pic
Originally posted by MIT
[B] i'm going to get the torque adjustable lbs wrench to tighten these plugs up to 13lbs.
tis might seem like a stupid question, but how do u measure the pound tightened with a wrench
Old Nov 17, 2003
a torque wrench has a torque meter on it, and it tells you how many ft-lbs of torque you're applying on the bolt/spark plug/whatever
Old Nov 17, 2003
Bellz's Avatar
On the back of my Denso box, it said to turn the plugs 1/4 to 1/2 turn to properly seat them. It's not that big a deal. They're not moving parts,like a cam, so torqueing them isn't as important. If you have a torque wrench, use it, otherwise 1/4-1/2 turn them. I didn't have a torque wrench, and they're working great.
About the anti-seize..use it if you want. It's to keep the plugs from getting stuck in there over time. It makes them easier to remove the next time they're changed. It's not about stripping the threads.
The easiest way to start the plugs is to put the new plug in the plug socket and put the extention bar on there. Start it with your hand, not the wrench. If it cross-threads, you'll know it quickly, it takes several turns before the plug snugs by hand and you can back it off and start again if it cross-threads.
Old Nov 17, 2003
MIT's Avatar
MIT
torque is important, cuz if too loose can overheat in engine, if to tight can hurt the engine..... just get one Husky torque adjusting lbs/ft at Home Depot, cost like $54.
Old Nov 17, 2003
SMX's Avatar
SMX
SMX is on a distinguished road
Blow off any accumulated road grime from around the plugs before pulling them out. Don't want any crap dropping in through your plug hole. If you don't have access to a compressor, find one at a service station. Cheap insurance.
Old Nov 17, 2003
SMX's Avatar
SMX
On the plug torque, the objective is to crush the washer correctly, but not too much. 1/2 a turn past finger seating is fine. Worry about proper torque when you're indexing your plugs for race use. If you're not racing (as in real racing, not just taking our cars to the track), using the 1/2 turn vs 13 ft-lbs torque doesn't matter.
Use anti seize if you don't change the plugs often. If you're doing it regularly, it doesn't matter as much. It all boils down to how seriously you take your mechanics.
thana
Jun 15, 2020 07:05 PM
Wild Cranker
427
Jan 28, 2016 06:49 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Micks2K1
Dec 10, 2001 07:11 PM
