o2 simulator HELP
Old Nov 11, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
o2 simulator HELP
ok, i got the o2 simulator from wannabfast. installed it. i turn the car to the on posistion. the CEL light goes off for about 20 seconds then turns back on.
i have the dc sport header with hks-a downpipe. i took off the wire to the o2 sensor. it has a clip about 12 in. from the o2 sensor. do i have to put that wire/clip back, and zip tie it under the car or what.
Old Nov 11, 2003
FuzzBeC00L's Avatar
Fuzzy Boy
Does it run good after it turns off and turns back on or what
Old Nov 11, 2003
Subrage's Avatar
it runs fine.
Old Nov 11, 2003
FuzzBeC00L's Avatar
Fuzzy Boy
A. the o2 simulator is ****ed up
B. sumone put the o2 simulator on wrong
C. just leave the o2 simulator on if it runs fine after the lil turn off
D. But a Tdi Jetta
E. I take sum store points hehehe
F.hahahaha
Old Nov 11, 2003
Subrage's Avatar
the lights turn on and off like their supposed to
well i checked and made sure i put it on right
the light wont go off.
d, e, and f are just way off topic
Old Nov 12, 2003
Subrage's Avatar
anyone?
Old Nov 12, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
i think you're still supposed to wrap the o2 sensor in foil or something...
Old Nov 29, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
You really need to find the wiring diagram that hooks directly to the ECU. I tried finding it, but I had no luck...I used this method and I haven't had a problem since.
Old Nov 30, 2003
jonfin's Avatar
jonfin is an unknown quantity at this point
Wgere did you get the simulator? Go to casperelectronics.com and they have it for like $60 or something, its already wired and has a harness that links to your stock 02 harness!!!
cleanride13
Aug 12, 2003 11:34 PM
2002vtecsir
Jun 21, 2003 06:14 PM
orion_squall
Apr 18, 2003 08:35 AM
R3DL1N3
Mar 17, 2003 02:10 AM
spike
Feb 21, 2003 03:46 PM
