IAT sensor question
Old Oct 16, 2003
hyperactive's Avatar
hyperactive is an unknown quantity at this point
IAT sensor question
ok. I took out my stock air box and "installed" a CAI,just the cone filter without the actual pipe. My IAT sensor is dangling on the side of the cone and when I started my car a CEL came on. What should I do? Is that bad for the car to have the sensor just hanging there? The light didn't come on before I started messing w/that whole cone filter thing. Should I just leave the sensor hanging and reset the light?
Old Oct 17, 2003
Alex1's Avatar
lol why would u do something like that? if u want noise just take off the resonator.
Old Oct 17, 2003
Voiceofid's Avatar
End Bringer
yes, that's bad, the iat tells the engine pretty much the tempature of air is going into that engine, and the fuel regulator changes the fuel settings according to it, some what. now your map sensor is reading a completely different reading than your iat, it's going to throw codes, because you pretty much created a faulty iat sensor situation
edit: wrong iat definition
Old Oct 17, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
The IAT determines the temperature of the air charge going into the throttle body. If the air is cold it will send a signal to the ecu and will throw more fuel at the colder air. If the air is hot you don't need as much fuel and will lean it out. If you are not getting a reading off the IAT your ecu will throw the CEL and run rich a f(u)ck and your gas milege will go out the window and your performance will fall through the floor.
I would just like to say that i think it is REDICULOUS that you took off your intake a put a cone filter on your throttle body..that's probably one of the dumbest things i have ever heard. You could spend 30 bux and get a cheap *** CAI off ebay and be better off. Your just asking for trouble doing what your doing.
The MAP is just how much pressure is in the intake manifold...
Old Oct 17, 2003
Voiceofid's Avatar
End Bringer
yes, but since our vehicle does not carry a maf, the map determines the amount of air is going into the engine, how else the car know how much air is being draw into the car otherwise?
Old Oct 17, 2003
7thGenerasianCivic's Avatar
You focked up...can you even close your hood with the gigantic filter sticking upward? LOL
Tedverseti
Apr 23, 2020 01:45 PM
juror
Jun 9, 2015 02:15 PM
juror
May 26, 2015 06:35 PM
bsmiley
Apr 27, 2015 01:27 PM
viper775
Dec 9, 2001 10:52 PM
