High compression
If I decide to upgrade and go with higher compression(thinking 10.8:1 from dh racing) how would I address the fuel issue? or is there even a way? thank you in advance for any help on this.
the computer should make up for the fuel mapping up to a certain extent otherwise you can search for the DIY of a inline fuel pump and slap a fuel pressure regulator on it and it should help with your problem
I don't want to go turbo due to all the ongoing maintence required with it. Its a non-stop process trying to keep it running and i don't want that. I'm going with the higher compression to have a little extra power under normal driving and nitrous is just nice for when you need that extra boost. But can anyone tell me if they've done this or not??? thank you
End Bringer
Re: High compression
mclean987 buddy...if you add more compression you need to add more octane or you will detonate. If you retard your ignition timing it is cancelling out the compression you just added...read your other thread i replied in more detail there...
If you want to make power you want to advance your timing...read up on some facts before YOU give advice on something your BUDDY doesn't know about.
And how do we know "Chrissy" even did anything she said??
Listen, Boo, I've been thinking about doing this too, and the computer should adjust for the higher compression. 10.8:1 isn't too high, but you will have to start using premium gas. I don't think there's one person on this site who's done this cuz they're all to scared or something. So be a pioneer and let us know. I just don't have the cash on me to do this project.
Its different trying to tune a d17 compared to a d16. If the D17 was easy to tune people would be doing it then........has anyone adapted an aftermarket radiator to our cars or is there one for it to address the overheating issue?
The whole package should cost you less that $1000. I could get it done for about $500 but I just don't have the money. My uncle is a mechanic and he could hook me up with cheap labor. The pistons/rings should cost you at the most $300 - $330. That's not including rods..
End Bringer
i never read the thread about the gx pistons chrissy had
but i am sure she probably killed her cat, and her egr
if it was simply adding higher compression pistons into the car, there would've already been d17s out there running that compression, obviously, it's more difficult dealing with that overheating than just a simple bigger radiator
hondata doesnt exist for our cars and never will according to them, i wouldnt say jet chip either, bc once u do it i dont think u can change it back correct me if im wrong, i retarded my timing with the emanage
[/rant]
what do i look like? a dyno?
j/k. seriously i don't know. it should add some actual "noticeable" power compared to what we have now, though.
again, NO ONE will know unless SOMEONE tries it, and then let's everyone else know.
darwin-t
Aug 15, 2015 10:51 AM
DerbyDad03
Jul 27, 2015 11:34 AM
CivicsClass101
Jul 9, 2015 11:14 AM
