Update On The Apex-i Vafc 2
Old Oct 25, 2003
TheChemist's Avatar
TheChemist is an unknown quantity at this point
My friend just bought the new apex-I vafc 2 for his 2002 civic ex, and asked me to install it for him, so I opened it up and checked the book to match up the engine with the ecu diagram. Here is the first problem the book shows h8-a [4plugs] ecu diagram for d17 engine but the [3plugs] ecu in the car looks like h7-a [3 plugs] ecu diagram for k20 engine so we called up Apex-I in Cali. We were told to use the [4plugs] h8-a diagram as it states in the book, few minutes later we find out that this year and model has still problems with the check engine light and it will not work, I'll say it again WILL NOT WORK. He said that they are in process of testing it, no date available on the fix. He said “only this year and model”, so I cannot say if it will work for 2k1 ex or 2k3 ex.
Old Oct 25, 2003
Vinh's Avatar
should work
Old Oct 25, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
so the 2002 is different from the 2001 and 2003 ? anyone have this on a 2002 ? does it work?
Old Oct 25, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
that makes no sense.. the only difference between 2001, 2002, 2003, and 2004, are just cosmetic. and some minor interior changes. all mechanics are the same.
and i believe there are like two members with complete and working VAFC-II's. namely Hwoody?
Old Oct 25, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
It works...I have it and it works without any problems
Old Oct 25, 2003
TheChemist's Avatar
which diagram did u use?
Old Oct 25, 2003
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
DIY on the vafc would be good? anyone??
Old Oct 25, 2003
obtix's Avatar
www.AbsouluteDriven.com
obtix is an unknown quantity at this point
I thought that they were going to stop making the VAFC?
Old Oct 25, 2003
cwick187's Avatar
I had the first VAFC and just used the the wire from that...It's the same except the orange wire from the VAFC 2 is used for the i-vtec (which you don't use) Just go by the VAFC wiring diagram and the ECU wiring diagram for our car. I think if you search you'll find them both
UltraHDGames
Jun 8, 2016 05:16 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Jrosa
Sep 14, 2015 08:24 PM
shaejb15
Sep 3, 2015 01:35 PM
2010 Civic
Aug 10, 2015 10:53 AM
