laptop into the ecu?
Old Oct 16, 2003
03civicdx's Avatar
03civicdx is an unknown quantity at this point
Question laptop into the ecu?
Is there anyway to hook a laptop into the civics computer? If so what do i need as for software and hardware and stuff.
Old Oct 16, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
its doable...derek ceo has one...it isn't really a laptop, its a carputer...u have to use a laptop HD, mobo, ram, and a custom LCD screen. That's just some insight, u have to figure the details by urself.
Old Oct 16, 2003
§C§H§O§C§O§B§O
oh...i dunno if it hooks up directly into the ECU or not...i doubt it though, u might need some converting device
Old Oct 16, 2003
03civicdx's Avatar
i just want to know if i can adjust fuel pressure manually and stuff like that cause that would be a pretty cool addition to have in my car
Old Oct 16, 2003
Vinh's Avatar
you watch the fast and the furious too much
Old Oct 16, 2003
03civicdx's Avatar
no i really am not a fan of that but i do know that fuel pressure is a big deal and if i could tap into that and change it manually i could moniter it for education and help to other members because i have to computer resources to do it
Old Oct 16, 2003
Blueboi105's Avatar
Blueboi105 is an unknown quantity at this point
buy the AEM Fuel management.. it has a Pc to ECU option or Pc to AEM unit to ECU
you should check their site
Old Oct 16, 2003
03civicdx's Avatar
whats the website and where can i get one
Old Oct 16, 2003
Blueboi105's Avatar
i think its aempower.com I'm not to sure.
Old Oct 17, 2003
§C§H§O§C§O§B§O
AEM, greddy and most other import companies make duel management systems, problem being, they dun have em for our cars (at least i don't think). good luck to ya
Old Oct 17, 2003
you can get an AEM plug and play programmable ems for 1281.55 shipped using the 7thgen discount at tornactive
is that the same thing..?
Old Oct 17, 2003
Civicious's Avatar
Civicious is an unknown quantity at this point
http://www.hondata.com/software.html
I think this is what you are looking for.
In addition to this I think you will also require an EPROM flasher.
Old Oct 17, 2003
opto_isolator's Avatar
I don't believe this is compatible with our ECU - there is no Hondata upgrades for our car.....
Old Oct 17, 2003
Civicious's Avatar
I sent them an e-mail to see if it is compatible or if they have any plans to make it compatible.
They have a sample download of the app here:
http://www.hondata.com/downloads/hondalogger.exe
Old Oct 17, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
One, you cannot change the fuel pressure. That is determined by the fuel pressure regulator in the tank.
Even with a programmable ECU, you could change the fuel map and the ignition timing. Change the timing too much and bad things happen. Change the fuel map to too lean, even badder things happen. Too rich, then you are wasting fuel and destroying your cat.
TUNING a car requires skill, a dyno, and is based on the exact CAR you are tuning. Base maps are available to start, but would not be optimum. Heck, you could tune a stock Civic to run on PREMIUM gas and advance the timing a bit, change the fuel curve, and it would have more horsepower. But that change would be small compared to the cost of an ECU and the tuning time.
What you would most likely learn is how fast you can destroy a perfectly good motor. No offense, but if you are asking how, then you do not possess the skills to really go in and start chaning things just to see.
Old Oct 17, 2003
03civicdx's Avatar
Thanks for the help civicious i appreciate you going so far out of the way for me, this new software for our cars is so simple and easy
Old Oct 19, 2003
03civicdx's Avatar
does anyone know where i can get the full version of the software and the cables needed? ive been looking around and been unsuccesful so far
Old Oct 19, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
You can't. If you want to use Hondata applications, you need a Hondata ECU. They don't make one for the D17. People, including me, have already contacted Hondata and they said that they aren't going to make one for our engine.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ttamrekab
Sep 28, 2015 01:22 AM
Dave Brabant
Sep 27, 2015 09:43 PM
260000milesgoal
Sep 25, 2015 07:41 PM
beanhead
Sep 24, 2015 12:04 PM
