resetting ECU ?
Old Feb 3, 2003
nme3's Avatar
JDM wannabe
resetting ECU ?
k, while searching this site it mentions to either disconnect the battery or pull out the 7.5 amp fuse to reset the ECU here and here and many other threads. But over here it says to remove the ECU AND Hazard fuses or else it would not completely reset. So is this right and okay to do?
Old Feb 3, 2003
RedDragon333's Avatar
I was under the impression that dissconnecting the batt. would do it. But i think it all depends on what your trying to accomplush but resetting it
Old Feb 3, 2003
tommyB16's Avatar
tommyB16 is an unknown quantity at this point
I think the battery will do it.
No need for the fuse.
At least it does on my car.
Old Feb 3, 2003
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
It can be done either way. If you disconnect the battery, you are disconnecting power to everything in your car. If you pull the 7.5a fuse labeled F.I ECU it will only reset your ecu, this means that you will not have to RE-program your radio and anything else running 12v (lo-jack). It's just easier.
my .02
Old Feb 3, 2003
VtecIvIc's Avatar
VtecIvIc is an unknown quantity at this point
are u guys sure its 7.5a?..because on the buse box cover it says taht the 7.5a is for interior light and underneath the 7.5 is the FI ECU..but that is labeled 15A..i have 2002 ex 5 speed by the way..maybe thats y its different?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 3, 2003
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
Use the fuse map under the cover and pull he fuse. It's easier to pull the fuse so you don't have to reprogram the sterio, espacially if you have one like mine that has like a hundred settings for color, time, E.Q., ect.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
lowlife9
Oct 6, 2015 04:39 PM
senicalj4579
Oct 2, 2015 10:03 AM
Hutch1051
Sep 29, 2015 09:20 AM
ttamrekab
Sep 28, 2015 01:22 AM
