cleaning mositure in head lights
Old Feb 2, 2003
btspeedz's Avatar
btspeedz is an unknown quantity at this point
hey, anyone know an effective way to clean the mositure in the head lights?
thanks
Old Feb 2, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
if they are stock bring it to honda and tell them to fix that ****.... otherwise, a hairdryer would work
Old Feb 2, 2003
MexMike's Avatar
MexMike is an unknown quantity at this point
If it is not much, garage your car and take the bulbs out so they can "breathe" overnight and it may evaporate itself.
Old Feb 2, 2003
emmc's Avatar
Venezuelan Member
emmc is an unknown quantity at this point
hairdryer.... are u talking about projectors or stock???
Old Feb 2, 2003
btspeedz's Avatar
its stock, its not dusty or brown and ****, but it does look like it would be good to give it a wipe, obviously i can't take the light apart...
any suggestion guys?
Old Feb 2, 2003
BumpinCivic2k1's Avatar
BumpinCivic2k1 is an unknown quantity at this point
take it to the dealer and get it fixed for free.
Old Feb 2, 2003
4bangin's Avatar
Quote
[hr]Originally posted by: btspeedz
obviously i can't take the light apart...[hr]
actually you can take the light apart if you want. there is a DIY for it when clearing your headlights. or just take it to honda.
Old Feb 2, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
If theres moisture in your headlights, and you haven't messed with them, meaning you haven't cleared them, then you should get honda to fix them. You may get a new set if they are leaking, if that really matters. If you cleared them, then just remove the main H4 bulb from the back of the lights, and get a hair dryer and dry it out. The moisture should eventually evaporate. If they are cleared, you may want to re-check the seal where both halves connect.
Old Feb 3, 2003
DathAnEteRnaLbBLuE's Avatar
DathAnEteRnaLbBLuE is an unknown quantity at this point
you should check all your seals first and the next time your lights are on if everything is sealed up the heal from the bulbs will dry the headlights out just keep checking on them to make sure
Or like a few people said if they are stock and not tampered with just take them to HONDA
Dathan
Old Feb 3, 2003
orso's Avatar
orso is an unknown quantity at this point
hairdryer. and recheck your seals. that happend to mine a couple of times.
trevor
Dec 4, 2001 04:12 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
cazminn
Nov 9, 2001 11:18 AM
sonsonzai
Nov 4, 2001 12:52 PM
