Reverse Indiglo Problem...
Old Jan 16, 2003
apracer211's Avatar
apracer211 is an unknown quantity at this point
Hey,
I bought Reverse Indiglo Gauges and installed them. Everything worked fine and they look great. My mph and gas gauge was a little crooked though. I took everything apart again, and moved the mph and gas gauge around so it was in the right position. I moved the rpm and temp gauge around a little too. When I put everything back together, I had a problem.
Around the center of the needle of my rpm/temp gauge, there is a little ring of light that seems to be coming from underneath the stock gauges. It was not there before. It looks like there is some separation from the stock gauge and the black center of the needle. Anyone know how to fix this problem? Also, just so everyone knows, the indiglos do not cover the stocks completely, and there is a small ring of stock gauge showing, but there was no light coming out of there before. When I get off work, Im gonna take it off again to see if I can fix this. Again, if anyone knows the problem or how to fix it, please let me know.
soul555top@yahoo.com
AIM: bigtopdogg211
I have attached a picture of the exact same gauges as mine, with a circle around the problem area.
ANY HELP WOULD BE GREATLY APPRECIATED!!!
thanks...
Old Jan 16, 2003
CarbonFly's Avatar
off topic but, That sucks that the one line below the 20mph doesn't light up.
Old Jan 16, 2003
apracer211's Avatar
yeah, everyone that was part of the group buy noticed that. they look really good though!
Old Jan 16, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
i want some that are all whitw with red letters that light up...Any one can help?
Old Jan 17, 2003
SatansEnemy's Avatar
SatansEnemy is an unknown quantity at this point
i know what you mean...mines the same everyone except the mph guage, i took it off and put it back on, and there was this little black ring that was under it, i had to pop it back in, i dont know if that was why my mph keep sticking or what, i thought that id try to fix that prob later, and i got some fingerprints on the black part os the guages also gotta go back in and fix that when i do ill play with the other, good luck and if you come up with something yell back at us.
thank you
Old Jan 17, 2003
apracer211's Avatar
so i kinda fixed the problem...
it is that little ring around the black circle thing at the end of the needle in the center of the gauge. i know that sounds a lil confusing.
i used a really small flathead screwdriver and carefully seperated the little ring and pushed it toward the gauge face. it was somehow attached to the bottom of the black circle thing at the end of the needle. it made a little *click* when it was back down. this fixed the light from coming out of the hole. only problem was that when i was messing with the little ring, i kinda bent a little corner, and light shows thru a little bit. jus be really careful, or i was thinking you could use one of those long exacto knives, the ones in the shape of a pencil. i dunno, but good luck! [IMG]i/expressions/beer_yum.gif[/IMG]
nirvanaguy
25
Oct 26, 2017 07:26 PM
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
