DIY M3 Mirrors???
Old Feb 4, 2003
Blckcivic01's Avatar
Blckcivic01 is an unknown quantity at this point
DIY M3 Mirrors???
anyone know how to install them or have any pics of them being installeD???
Old Feb 4, 2003
RiceBuRNeR's Avatar
Turbo Member
You need to remove your sail pannel (the panel that hold the tweeters in an ex) I removed my door pannels but I cant remeber if its nessesary. Then the mirrors are held in by three nuts, that youl have to replace w/ screws when you put your m3's in. I used a volt meter to determine wich wire is was wich on the stock mirror controlls and then spliced them into their corasponding wires on the m3's. As far as the lights I havent hooked them up yet, Im going to wait untill I remove my doors to repaint my car.
Old Feb 4, 2003
nytejade's Avatar
nytejade is an unknown quantity at this point
I advise that you check out the mirrors closely before installing them. I've had mine on for a few months now and I"m starting to get sick of the way they look. The driver's side mirror actually sticks out further than the passanger side mirror. Make sure you check to see if one is longer than the other. They look great, but when you look at the car head on you can clearly see that the driver side is sticking out more and it looks like crap in my opinion. Just thought I"d give you a heads up before you wasted time installing them. I'm actually uninstalling mine tonight if it's not too cold. I'm sick of thinking about it. The stock ones look cool anyway.
Old Feb 4, 2003
dragoon's Avatar
Quote
[hr]Originally posted by: RiceBuRNeR
You need to remove your sail pannel (the panel that hold the tweeters in an ex) I removed my door pannels but I cant remeber if its nessesary. Then the mirrors are held in by three nuts, that youl have to replace w/ screws when you put your m3's in. I used a volt meter to determine wich wire is was wich on the stock mirror controlls and then spliced them into their corasponding wires on the m3's. As far as the lights I havent hooked them up yet, Im going to wait untill I remove my doors to repaint my car.[hr]
what he said, its easiest to remove the door panels because itll be easier for you to get the tweeter pods out. for the lights, the best way is for you to check the polarity of the wires (for the mirrors and turn signals) and just splice em in there.
gearbox
Lighting
467
Oct 16, 2017 02:03 PM
Genyc07
Jun 28, 2015 04:55 PM
ironcow
Exterior DIY
Apr 9, 2012 10:04 AM
Stephon314
Feb 23, 2004 08:49 PM
Sampsonite
Apr 2, 2002 10:48 PM
