Racing Seats and SRS light
Old Jan 31, 2003
scatman's Avatar
Still in the game...
Im getting the tenzo r seats soon and i was talking to one of my buddies and he said that i might have to reset the srs light if i take the seats out to swap them, is this correct??...let me know before i get them so it wont be a hassle.thanx
Old Jan 31, 2003
4bangin's Avatar
why would you have to, unless you have side air bags. by the way, i hear the tenzo r's fad.
Old Jan 31, 2003
RedDragon333's Avatar
I got the same seats and if you have side airbags the light will go offf, and make sure you get the sliders and brackets made for the 7thgen otherwise your gonna have a he!! of a time.
Old Jan 31, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
good thing red dragon has those seats or else you would have to [IMG]i/expressions/moon.gif[/IMG] bend over and get screwed cause your light would be going off all the time...
INJEN
Old Jan 31, 2003
XxPloSiv2k1Lx's Avatar
XxPloSiv2k1Lx is an unknown quantity at this point
what if we put some sparcos? im not sure if they made a bracket for our car........
Old Jan 31, 2003
dragoon's Avatar
your SRS light will still be on
Old Jan 31, 2003
cdmx's Avatar
I reset my srs light with a paperclip
Old Feb 1, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
when you unplug the seat sensors it trips a SRS code..whether you have side SRS or not.
Old Feb 1, 2003
dragoon's Avatar
can you reset the SRS light if the seats remain unplugged?
Old Feb 1, 2003
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
just make sure you leave the ignition off, don't even have the key in the on position and you shouldn't have a problem with your srs light. disconnect it, swap the seats, and then turn the car on, the srs light should not stay on...do the tenzo seats really fade???
Old Feb 18, 2003
HCCriminal's Avatar
an0therpin0y
Quote
[hr]Originally posted by: HondaSales
just make sure you leave the ignition off, don't even have the key in the on position and you shouldn't have a problem with your srs light. disconnect it, swap the seats, and then turn the car on, the srs light should not stay on...do the tenzo seats really fade???[hr]
disconnect it ? how ?
Old Mar 8, 2003
dragoon's Avatar
Quote
srs light came on and stayed on when i did that on my 02.
Old Mar 8, 2003
CarbonFly's Avatar
Quote
[hr]Originally posted by: cdmx
I reset my srs light with a paperclip [hr]
How did you do that?
How do we bypass the SRS? My seats come in this week.
Old Mar 8, 2003
dragoon's Avatar
Quote
[hr]How to reset your SRS light on your civic. This works for 99-00 Civic's as well as 2k1's. What is pictured is actually a 2k1 but the plug for the 99-00's are in the fuse box also, just on the other side of the column.
1st you need to either buy or make the "SCS Service Connector." I used a speaker harness for and older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly.
2nd you need to find the MES (Memory Erase Signal) connector which is pictured below: (Click to enlarge)
MES Plug in Fuse box.
SCS Plug
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
[hr]
I'd like to know how to disable it also, because I'm getting my Celica seats tomorrow.
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
