Jacking up car, jack stands, hi-lift, etc
Old Jan 29, 2003
cheesy9999's Avatar
cheesy9999 is an unknown quantity at this point
I need to jack up my stock 02 coupe. I've never jacked it up before. My friend has jackstands and a Hi-Lift that he uses for his Jeep. Should I use the Hi-Lift or the jack that came with the car (for changing the spare tire)? How should I do it? Should I do one corner at a time, or the front then the back, or visa versa? Is there a place on the front and rear where I can put the lift without damaging the bumper?
Pictures would be great, but any help is greatly appreciated.
I just want to make sure I'm safe as possible and not damage the car (or myself).
Old Jan 29, 2003
666's Avatar
666
666 is an unknown quantity at this point
I think your owners manual has some nice pictures and descriptions.
Old Jan 29, 2003
4bangin's Avatar
see below. do not know why it double posted like that.
Old Jan 29, 2003
player's Avatar
its all in the manual man, use the jack that is given to you , there is a certain place behind your front wheel and infront of your back wheels were the jack clings to the car, but u can only lift the car one corner at a time.
Old Jan 29, 2003
cheesy9999's Avatar
hmmm....maybe i should check out this "owners manual" thing i keep hearing about...
Old Jan 29, 2003
4bangin's Avatar
do not use the stock jack. there was a post a while back about the stock jack giving way and coming down. if you are going to work on your car get a better jack from an auto parts store (got mine for around 40 bucks). only use the stock one when you absolutly have too. jack stands are good. never used a hi-lift.
Old Jan 29, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
Quote
[hr]Originally posted by: 4bangin
do not use the stock jack. there was a post a while back about the stock jack giving way and coming down. if you are going to work on your car get a better jack from an auto parts store (got mine for around 40 bucks). only use the stock one when you absolutly have too. jack stands are good. never used a hi-lift.[hr]
shouldn't there be a recall on the stock jacks then??
Old Jan 29, 2003
cheesy9999's Avatar
Ok I looked at the manual but it only shows you the stock jack. Could I use it just to get it up on jackstands or could I use my friend's hi-lift? I don't really want to buy another jack just for this one time thing.
The manual doesn't say anything about jacking it up from the front or rear using a jack or hi-lift. Is this possible?
Old Jan 29, 2003
just use the factory jack and then put it on jack stands. u never want to work on a car with only the jack holding it up.
Old Jan 29, 2003
cheesy9999's Avatar
I know you dont' want to work under a car with just the jack holding it up.
Will the stock jack go high enough to put jack stands under it? Is it ok to raise it one corner at a time?
Old Jan 29, 2003
yea it will go pretty high. but what are u working on ur car??
Old Jan 29, 2003
born2xLr8's Avatar
I've done a lot of things under the car. Headlights (which i later found out...didn't need to take bumper off) and my cat-back system. Lifing one corner at a time is really the only way to do it (ie. changing a flat in the middle of the desert.) I suggest using anything except the car's stock jack. That thing is cheap and not reliable IMO. Use your friends jack then use jack stands to be safe.
I don't think civics can be lifted from the front or the back.
Old Jan 29, 2003
cheesy9999's Avatar
Quote
[hr]Originally posted by: asianmatrix02
yea it will go pretty high. but what are u working on ur car??[hr]
i have a feeling people here are going to make fun of me, but since you asked, i'm installing an underbody neon kit.
Old Jan 29, 2003
oh, well in that case use ur friends jack. i thought u were changing tires.
Old Jan 29, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
use the factory jack, or go out and buy a floor jack for $35 at pep boys. The hi-lift won't work unless he has an extension (the lever isn't long enough to reach the jack points.
Old Jan 29, 2003
cheesy9999's Avatar
Hmmm...$35 isn't too bad. Plus then I won't have to take my whole subwoofer system out of my trunk to get the damn jack [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 29, 2003
born2xLr8's Avatar
I bought my 2 ton floor jack at Kregan for $15. Works just fine.
Old Jan 29, 2003
XxSoVeReiGNxX's Avatar
That stock jack is a bit dinky. It's scary getting the car up even only 2 inches from where the tire touchs the ground. Looks like it'll snap.
Old Jan 29, 2003
cheesy9999's Avatar
approximatly how much do 2002 civic coupes weight? i'm too lazy to check [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 29, 2003
clownprince's Avatar
Ricerus Maximus
Get a two-ton jack from the auto parts store and use jack stands. Or if you have them at your disposal, you can use ramps, that's what I used. Careful not to scrub the front bumper though. Don't always rely on the stock jack, IMO it's mainly for emergency use. The owners manual has all of the lift points for the car, DO NOT jack the car from the front or the back, there are no jack placements. With a 2-ton jack, you can raise the side of the car high enough to get both jack stands for that side under the car.
Old Jan 30, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Quote
[hr]Originally posted by: clownprince
The owners manual has all of the lift points for the car, DO NOT jack the car from the front or the back, there are no jack placements.[hr]
eh, I've been using the front 'jack point'. It actually has an arrow pointing to it. No problems yet. I use a 2-1/2 ton floor jack with a nice big jack pad/cup that fits the front jack point nicely.
Old Jan 30, 2003
solar's Avatar
solar is an unknown quantity at this point
Under the center of the front bumper there is a arrow pointing to a "lift pad" the pad has a hole in it. Center your jack under the hole, put jack stands on the lift points just behind the front tires,(you'll see where the metal is notched out). If you jack up the back center the jack under the metal tow loop and place the jack stands in front of the rear tires on the lift points.
I bought a high lift 2 ton jack and have used it many times with no problems, I needed the high lift because my other jack wouldn't raise the car high enough for me to place the jack stands under the car.
Old Jan 31, 2003
cheesy9999's Avatar
OK it turns out my other friend has a floor jack...the kind that slides under the car and raises the whole thing up.
I think I'll use that [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 31, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
I've seen the stock jack work fine and break but under certain conditions.
And that condition is...
If your aftermarket wheels are heavier than your stock wheels do NOT use the jack that came with the car, because it WILL eventually fold and result in your car hitting the ground pretty hard. You can hurt yourself or your car. All in all, I wouldn't recommend it.
My experience comes from me needing to have my car jacked up after it was a few days old with the stock jack from a flat tire. Then my friend's Civic was raised with the stock jack and he had heavy 17s on his car. We tried lifting it up from the front left side and the jack didn't last long at all when we were done getting it in the air.
Old Feb 1, 2003
cheesy9999's Avatar
I ended up using my friend's floor jack and it worked well. We lifted it from the front and rear, but when we tried lifting it from the side it dented the undercarriage [IMG]i/expressions/face-icon-small-confused.gif[/IMG] ...oops. hopefully it didn't crush anything important.
Old Feb 1, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Quote
[hr]Originally posted by: cheesy9999
approximatly how much do 2002 civic coupes weight? i'm too lazy to check [IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
2500 LBS, more depending on trim and other additons...
-Mark
LionSpratt
Jan 29, 2017 11:07 PM
usajags84
May 10, 2015 08:11 AM
nickfn
Nov 8, 2001 09:44 AM
GabberHead
Bolt-on Engine Performance
Nov 6, 2001 10:53 AM
