Wiring power windows into dx???
Old Jan 21, 2003
2k1coupe's Avatar
2k1coupe is an unknown quantity at this point
I recently ripped the power window's out of a wrecked lx at the junkyard for my dx 2dr. The installation into the dx is not plug and play however. The dx modifies the wiring harness before going through the door because only speaker wires are needed. I need to splice the new lx door harness into the dx's harness. Can anybody identify the wire colors for me?
Someone on this site has already done this.
Old Jan 21, 2003
jefff's Avatar
jefff is an unknown quantity at this point
As long as you wire the switch properly, you should just be able to splice into anything that has power when the car is on I think.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 21, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
you should of also got the wirering harness that would also let you use the stock switches but hey..you can just wire it to a toggle
Old Jan 21, 2003
2k1coupe's Avatar
Quote
[hr]Originally posted by: CivicRicer02
you should of also got the wirering harness that would also let you use the stock switches but hey..you can just wire it to a toggle[hr]
I have the wiring harness that connects to the stock switches. Wires run from the motor to the switch and from the switch to the main wiring harness through the door. I can only identify the ground.
Old Jan 22, 2003
2k1coupe's Avatar
bump.
Old Jan 23, 2003
WhiteRabbit's Avatar
the wiring takes some play to figure out. alls you gotta do is run a singlular 12 volt source wire in there, id go direct from teh battery so you can run your windows even with the car off.
as to exact wiring, youll have to play, but basically, through teh grommet into your door goes teh motor wires from teh passenger door and the one 12 volt source wire. everything else should be internal, unless honda made some crazy power window control set. if its jsut your basic switch, then this will be how it works. you can use a dmm to make sure none of the leads your playing with power are connected, so you dont short anything out.
eventually youll find 2 leads where the power will work, all it takes is time. then you can splice teh wires and call it a day. simple!
Old Jan 23, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
look for red/black (for up) and red/yellow to control the drivers window. the passenger should be blue/red (for up)and blue/white. These are reversing polarity wires, so once you figure out power and ground to the switch, they should be easy to test. The remaining wire(s) are your illumination.
Old Jan 24, 2003
rijowysock's Avatar
ThE FaMiLy SeDaN
so in order to make DX with power windows, all i would need for my GF is the motors out of a LX and the Switch plate? would anyhting else be needed except for alot of time and splicing wires????
riley
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
