Throttle Cable Question
Old Dec 5, 2003
sembene's Avatar
sembene is an unknown quantity at this point
This is for all of you who tightened their throttle cable and brought up the rpms: did you notice any loss in mileage (mpg)?
I'm thinking of slackening the throttle cable slightly to maybe increase mileage....
Old Dec 5, 2003
manu's Avatar
manu is an unknown quantity at this point
hey dude you're supposed to tighten the throttle cable but not
as much that it brings up the RPM'S. If the RPM'S are up from normal
then u went too far . And of course if ur RPM'S are up then it takes more
gas to do that and you obviously are gonna see your MPG go down .
You tighten the cable so when u push the gas pedal ur car reacts faster
thats the only reason why you do that , just untighten it a little and you'll be fine .
Old Dec 5, 2003
7thGenerasianCivic's Avatar
^^^ ditto
Right now you are basically letting your throttle body plate open and letting air in. Therefore more air = burn more fuel = waste gas = lower mileage.
Old Dec 5, 2003
CivicHX01's Avatar
slacking(dunno if its a real word) it more than stock isn't going to bring down your gas mileage.. its just gonna delay the response your car makes when you press the gas pedal...
a good throttle cable is tight enough to give you instant response, but it shouldn't raise up the rpm...
Tedverseti
Apr 23, 2020 01:45 PM
NoobyKid
Jul 13, 2015 07:53 AM
chrisjackson321
Jul 12, 2015 03:00 PM
muttleytm
Jul 11, 2015 06:00 PM
Ccoop87
Jul 9, 2015 03:26 PM
