Holy Crap... my gauges
Old Dec 16, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Unhappy Holy Crap... my gauges
I tried installing the reverse indiglos... i pulled the needles straight up, and now when everything is installed, ALL the needles went wacko. Please guys...
what are my options?
what did i do wrong?
Old Dec 16, 2003
civicvtec1ps's Avatar
Search and Learn
You fooked up the gauge cluster.
Time to buy new one. Does gauge cluster even work now?
Old Dec 16, 2003
MangoEX's Avatar
Just Be
But lets say I buy a newone, I still want to install the gauges.. how do i do it properly? I pulled straight up on the fk*in needles! and put them down STRAIGHT on!
Old Dec 16, 2003
MangoEX's Avatar
Just Be
and what about the milage?
Old Dec 16, 2003
aznrj's Avatar
aznrj is an unknown quantity at this point
you don't have to buy a new one. just recalibrate at the honda dealership. all they need to do is plug your SCS connector to the computer and reset the standards.
Old Dec 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
wtf did u do wrong.....u pulled the needles off that what, two maybe honda can recalibrate them now but when i did that they had to get me a new cluster, send it out to put the mileage on it and then re install it, all under warranty of course
Old Dec 17, 2003
Okay, what exactly did you do? I've taken mine in and out over 20 times and never had a problem. I think they're supposed to reset when you plug the cluster back in?
Did you pull them out at their resting positions and put them back in the same way? Getting a new cluster is not a good thing. Your mileage will be whatever is on the old cluster and will ruin the resale value of your car. If you get a brand new one, the mileage will be 0.
Try and put everything back and take it to Honda. Just say you don't know what happened and they might fix it under warrenty.
Old Dec 17, 2003
Another idea. Did you push the needles down completely? If you did, they may be sticking to the face. Try and put them on halfway or something and see if that does it.
Old Dec 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
correction
1.getting a new is better
2.mileage on the old one, hello way better bc u keep on driving while they set the mileage
3.therefore not ruining the resale value
4.getting a new one will not set the mileage at 0, honda is dumb most of the time, but they aint going to give someone a cluster and put 0 miles on it, they send it out and have it set
Old Dec 17, 2003
Honda will not send it out. At least the one in my area won't. They said they will put a sticker inside the door that says mileage was reset on this date. If you get one with miles on it already, that's fraud and could get you in trouble if you ever sell the car. A new one comes from the factory with 0 miles. Mileage is stored within the cluster, but there is also a place in the ecu that keeps track of real mileage. It can be checked to verify miles.
Old Dec 17, 2003
C2i0v0i1C's Avatar
SuperMODrizd
maybe it was ur honda then, mine took the old one, got me a new one, sent it to michigan, had it set, to the mileage on the messed up cluster then put it in and sent me on my way
Old Dec 17, 2003
cryption's Avatar
2003 Nissan Frontier
my needles just sick when i get to around 80, and i just deal with it because i dont want to have to take it apart again ... any options if i decide to fix it?
Old Dec 17, 2003
cryption's Avatar
.... after putting on guages
Old Dec 17, 2003
Don't put the needles on all the way! Just halfway is good enough, so the base isn't touching the face.
Old Dec 17, 2003
BlackIce's Avatar
BlackIce is an unknown quantity at this point
why did you take the needles off in the first place, I didnt have to when I installed mine. Interesting...
Old Dec 17, 2003
Chris filidei's Avatar
Chris filidei is an unknown quantity at this point
when i did it i didnt take off the needles just bent them up and if its sticking when u get to 80mph its because the gauges arent flush against the back i had to super glue them down then after that i didnt have any problems try that
Old Dec 17, 2003
gizcivic's Avatar
gizcivic is an unknown quantity at this point
i did the same and after they stuck i replaced it beack to stock
and went to dealer told them it just started to stick they replased it
with a new one and mine was at 0 when i got it i ask them y and they showed me the sticker on door honda tecks are so lazy
ps. my father works for honda they can put org miles on it
Old Dec 17, 2003
ojjr22's Avatar
ojjr22 is an unknown quantity at this point
I heard someone on here say that when you plug in the new cluster it goes to the mileage that is on the car. I think the miles are stored in the ecu and not the cluster. I may be wrong though.
Old Dec 17, 2003
cryption's Avatar
i never took my needles off ... i guess i need to pull them and make them a little higher so they dont rub and not stick?
Old Dec 17, 2003
cryption's Avatar
and mileage is stored in the cluster
Old Dec 18, 2003
gizcivic's Avatar
but if you get a new one it is at 0 miles
Old Dec 18, 2003
Bellz's Avatar
Skipbarber's Gauge Cluster FAQ. People should not offer opinions if they don't know what they're talking about. Gearbox and Gizcivic are correct!!
When swapping clusters, you can have Honda put a sticker on the door jam or they can flash the new cluster to the correct mileage.
And actually mileage IS SAVED in the ECU.
http://www.7thgencivic.com/forums/sh...hreadid=119894
Old Dec 18, 2003
john_817's Avatar
john_817 is an unknown quantity at this point
i dont think u were even suspose to touch the needles... i think theres a diy in the diy section
Old Dec 18, 2003
cryption's Avatar
when i put my guages on i didnt touch the needles ... just worked around them
Old Dec 18, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
same thing happened to me. i took my needles off and everything went crazy. i took it back to the dealer and they gave me a whole new gauge cluster. resetted my odometer back to 0. so now i have to add 5760 to the odometer to get the actual milage. im thinkin about takin it back to the dealer to get them to add on the milage.
Old Dec 19, 2003
pheaton's Avatar
A descendant of 2k1civic.com
See if they'll add HP when they add mileage.
Worth a shot. .
Old Dec 19, 2003
I've had my needles out so many times and they're still fine. I even once pushed one below it's stop point. As long as they're in the right position, it should reset. If not, you can always take them out and try new positions.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
