How often to bleed clutch?
Old Nov 16, 2003
odie's Avatar
odie is an unknown quantity at this point
How often are we supposed to replace clutch fluid?
The manual doesnt mention intervals for clutch, but
it does give an interval for replacing brake fluid,
which is the same fluid used in the clutch, so are
we to assume you should bleed at the same interval
as brakes? Or is it like steering fluid... don't flush it
ever... just refill when runs low???
Old Nov 17, 2003
solar's Avatar
solar is an unknown quantity at this point
The fluid in your clutch doesn't get anyware near the pressure the Brake Fluid gets on your braking system, so changing it really isn't nessarsary.
Old Nov 17, 2003
CivicHX01's Avatar
do you mean manual transmission fluid (MTF)?
if you do, i changed mine at 30k with synthentic 10W/30 oil which is the same viscosity as MTF...
instuctions on how to change the fluid is in the manual...
Old Nov 17, 2003
CivicHX01's Avatar
oh nm... i read wrong... the clutch fluid doesn't really need to be changed, it just needs to be topped of every once in awhile
Old Nov 17, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I'd get that out of there and dump some Honda MTF in ASAP. If no other fluid remains Honda, make sure the tranny fluid does. Its got additives to prevent synchro wear that none of the other MTFs have in it. It has to do with the materials that they made the synchros out of, its pretty much an agreed upon fact... use the Honda stuff.
And as far as I know... you only need to bleed the clutch when it gets squishy. If you never mess with it, it should stay sealed as long as nothing is leaking, then it shouldn't need to be bled very often.
Old Nov 18, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
yeah its not the same as oil I think the tranny fluid is like 75w90 so your really gunna mess something up!
Old Nov 18, 2003
blustrek01's Avatar
blustrek01 is an unknown quantity at this point
no fellas. the trans fluid is the same as the motor oil. you can use 5w-30. which is the same as what i put in my motor. full synthetic.
Old Nov 18, 2003
eviLsliDinciVic's Avatar
eviLsliDinciVic is an unknown quantity at this point
If you take you're vehicle to you're dealership for any maintenance check ups or anything..not sayign most of you do..But in my case I do considering mine is a lease..But they check that for you everytime you change you're oil unless you do it yourself..
Old Nov 18, 2003
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
I thought most tranny fluid was aroudn 80W-90. At least that is what we used mainly at Dodge when I worked there as a mechanic? Does Honda use a different oil? I was under the impression that most car manufacturers used the same thing.
Old Nov 18, 2003
Jap-Euro Fusion
You guys are thinking of differential gear oil. Thats like 80W90 or something like that. The manual says you can use motor oil as a temporary tranny fluid, but it then says it doesn't have all the wear additives in it that the actual MTF does.
Old Nov 18, 2003
All the dodge ram and dakota's that we service here at Riverside dodge that have manual tranny's all use 80w-90 synthetic lately.
Old Jun 1, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I would never put motor oil in my tranny, esspecialy when theres a Honda dealer on my St. and the fluid is $4 a quart!
Old Jun 1, 2005
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
^Amen brotha
Old Jun 3, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
YOU can use REGULAR MOTOR OIL. If your getting charged $4 dollars for motor oil your getting ripped off. If you read any manual for honda thats what they call for, NOT as a TEMPORARY solution, but that is what honda uses. It bassically is less viscious oil that allows it to circulate threw the transmission faster and smoother. drain your transmission and you will see. You dont get that pink fluid in a honda. its more like a black murkey mess like what comes out of your engine :-D.
anywho.. this thread wasnt about what to put in your transmission it was about if you should change your clutch fluid. the answer to that is you can if you want but you dont need to.
Old Jun 3, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Bleed the clutch when you have the brakes bled. The only reason you want to do this is because brake fluid attracts moisture. After a while it can start corroding the aluminium in the master and slave cylinder. If you plan to keep the car a long time, change it every 35k or so. If you trade it in in 5 years or so, don't bother. It takes (usually) 10 years or so before the fluid corrodes the brake and clutch system. I bleed out my Nissan truck every 2 or 3 years, and it is still fine. It's 20 years old now. Same brake and clutch cylinders.
So it's really only a maintenance thing, if you keep cars a long time. With the brakes, you bleed new fluid in if you overheated the brakes and made the fluid boil. So if you do intense driving (with a civic???) you should change the fluid more often, but this does not apply to the clutch fluid since it never gets hot enough to be harmed.
Old Jun 3, 2005
2K1Civic17"Gabe's Avatar
hehe, I need new brake fluid I guess. I overheated them many times lately. I figure if I mess something up, time for slotted rotors, performance pads.
Old Jun 9, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
can someone tell me how much quarts the 5 speed tranny takes for oil change?
Old Jun 9, 2005
flotsamm's Avatar
Its in the manual I think.. buts its only like a couple of quarts.
Old Aug 17, 2010
gangulyarchan's Avatar
gangulyarchan is an unknown quantity at this point
Re: How often to bleed clutch?
@ mclean 987 - It will take 1.5L (almost one and a half quart) for a 5 speed 7th Gen Civic.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
Klame9420
Sep 7, 2015 10:03 PM
thaler4cuse
Sep 7, 2015 08:25 PM
