When jacking your car up...
Old Nov 16, 2003
SimplePinoy's Avatar
SimplePinoy is an unknown quantity at this point
Question When jacking your car up...
At what poinit on your car do you place your jack to lift your car so that the whole front end is up? my car is lowered so i drive up on 2x4's to give me enough space to get the jack under my car. but then where do i jack it up from?? thanks in advance for info.
Old Nov 16, 2003
meth's Avatar
meth is an unknown quantity at this point
underneath the driver's side and passenger side door there are 2 longer parts of the underneath of your car.... they're reinforced for the jack. they're right behind the front tires. you jack it up there.
Old Nov 16, 2003
But that only lifts that side of the car, what if i want the whole front end up?
Old Nov 16, 2003
meth's Avatar
hmmmm.... you could use 2 jacks one on each side.... it might be able to lift it up enough. ???
Old Nov 16, 2003
lift one side up, put it on a jack stand, lift the other side up, put it on a jack stand, there you have it, front end lifted
Old Nov 16, 2003
meth's Avatar
yea, that's kinda wut i meant, but i forgot bout the jack STAND part... lol my bad
Old Nov 16, 2003
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
You can easily hook the jack up underneath the tow hook. That is the recommended place to put the jack. And it lifts the whole front end up at once.
Old Nov 16, 2003
this'll probably make me sound really stupid, but where is the tow hook??
Old Nov 16, 2003
look underneath the car. in the center. It is a loop in the back. In the front there will be an arrow pointing to a plate that sticks out from the plastic trim piece.
Old Nov 16, 2003
cdmx's Avatar
This is what i do, and i have to drive up on wood also.
sometimes i lift the car up as much as i can than i push the jack in with my knee....(my back! )
Old Nov 16, 2003
cool. thanks guys
Old Nov 16, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
for jacking up the front of the car (this is best if using a floor jack), underneath the radiator fan, on the chassis, you will see an arrow pointing to the center part of the frame. this is also a jack point.
Old Nov 16, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...48#post1523148
Old Nov 16, 2003
OmegaStauf's Avatar
OmegaStauf is an unknown quantity at this point
Since the jacking points are only wide enough for the jack, do you jack on the jack point and then put the jack stand next to the jack point or do you jack next to the jack point and put the jack stand on the jack point?
Both ways seem to work but it seems like that section under my car is just a little bent (probably the molding bending a bit), so I'm just curious.
Old Nov 16, 2003
Renamazazo's Avatar
The section under the car isn't bent, that's just the plastic shroud underneath the car getting pushed a little ouit of the way.
This is how i've jacked my car up, it worked fine for me.... much easier than trying to fit the jack under the non re-inforced area's...
Old Nov 16, 2003
7thGenerasianCivic's Avatar
I jack from the same area.
Old Nov 16, 2003
slicksivik's Avatar
i try jacking ym car up on those reinforced flat areas on teh sides, but my friggin side skirts cover the spots up. i tried jacking it up farther down teh side and it got up like a foot over my rim and it was still on the floor and i just lowered it cuz i thought my car was gonna get messed up or something
Old Nov 16, 2003
Renamazazo's Avatar
JUST USE the front mounting point... if you can't get a jack under there... then, go buy a lower profile floor jack.
Tedverseti
Apr 23, 2020 01:45 PM
ChristinaVHH
May 10, 2015 03:51 PM
nickfn
Nov 8, 2001 09:44 AM
GabberHead
Bolt-on Engine Performance
Nov 6, 2001 10:53 AM
