wires connected to seat?
Old Dec 7, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
ok, i dont have side airbags, but im trying to figure out what the connectors under the seats are
do they need to be plugged in if you put in aftermarket seats?
Old Dec 7, 2003
Electriclogic's Avatar
Electriclogic is an unknown quantity at this point
There should be a connector that is for the seat belt sensor. It lights up to remind you to use seat belt.
Old Dec 7, 2003
numbaonestunna's Avatar
numbaonestunna is an unknown quantity at this point
once you take it out, you need to something. i believe the check engine light will come up. i had a honda tech reset it for me. he did something under the steering wheel. he said its for the air bags. i dont have side air bags either. i guess its the for the fronts. correct me if im wrong. *shrug
Old Dec 7, 2003
skipbarber's Avatar
no the CEL but the airbag light will come on. once that airbag light comes on, the airbag system is deactivated. they dont want the bag to come out if your seatbelt isnt buckled...cuz that would probably hurt.
Old Dec 7, 2003
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
can you rip sensors from old seat, and stuff them into the new seat? this may allow you to preserve the sensors, although they may not work 100%.
Old Dec 8, 2003
skipbarber's Avatar
^nope...the only way to keep the plug intact is to remove the seatbelt latch from the seat and install it on the new seat...it would require some customizing, but it would work.
Old Dec 8, 2003
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
I guess installing a set of front racing seats can be difficult then ? Esp. with the seatbelt sensor.
Old Dec 8, 2003
04civiclxguy's Avatar
Got Capitalization?
04civiclxguy is an unknown quantity at this point
The Wire's Under The Seat Are For The Seat Belt and The Seat Belt Indicator For The Instrument Panel. Dude if you Put In New Seats be Very Care-Full.
Old Dec 8, 2003
civic01vtec's Avatar
ummm........that plug is for the automatic seat belt adjusters. The SRS light will come on if disconnected, SRS is for the seal belt adjusters or side air bags if equipped.
Old Dec 8, 2003
Samari's Avatar
just plug them in. its not a big deal if you have after market seats.
Old Dec 8, 2003
yeah, but after u plug them in, the light still stays on.
Old Dec 8, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
Yeah i had that problem when I took my seats out to put sound deadender down... the SRS stayed on whenever I reconnected everything, I had to take it to the dealer, anyways... i wonder what every one with aftermarket seats is doing so the SRS doesnt stay on....
Old Dec 8, 2003
Samari's Avatar
i took my seats out and plugged them connectors back it and no light came on.
Old Dec 9, 2003
halflife's Avatar
halflife is an unknown quantity at this point
be very very careful with that connector. I had custom leather installed and they bent the connector. The air bag light came on and it took me a while to find it. the little wire in the connector was pushed to the side and very hard to see. I had to splice the wire and solder them together.
Old Jan 27, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
I know this thread is old but i have a question about side airbags.
i have a 2002 civic ex sedan, canadan version. they dont come with side airbags! is it possible to add side airbags to me car?
thank you
Old Jan 27, 2004
Got Capitalization?
wire under the seat is the connects to the seat belt connector witch connects to the intrument panel wheres theres a seat belt reminder light.
Old Jan 27, 2004
thank you
i'm sure it can be done........but it prolly won't be cheap
Old Jan 27, 2004
skipbarber's Avatar
youll need the module and wiring.
Lopes101
Jun 7, 2015 08:04 PM
Blazz
May 25, 2015 10:56 PM
Fastfebur
Apr 22, 2015 01:37 PM
Dmitri
123
Oct 13, 2005 08:01 PM
pimpedcivic
Jan 5, 2002 11:00 PM
