*****I need some quick help*****
Old Aug 5, 2005
MugenTak's Avatar
My car breaks and explodes for no apparent reason.
MugenTak is an unknown quantity at this point
Alrighty guys, I need to get my header off of a 2001 Civic EX. I'm running into a slight problem. The header nut on the drivers side (the right side if you're looking at it from the front) is stripped. I guess whoever had the car before stripped it. I need to get that nut off so I can pull the header off the car and put the new one on. I really don't care if I destroy the stock header or the nut, but the stud that goes into the block needs to remain intact. It's very tight, not much more than my index finger can fit down there. Any suggestions on how to get it off? TIA.
*I did a quick search and couldn't find anything.
Old Aug 5, 2005
Jrfish007's Avatar
WD-40. Lots of it.
Spray some on, let it set for a few minutes, spray some more on, let it set for a few minutes and so on. Try to wiggle the bolt a little each time, but not to hard, you don't want to snap to top off. Make sure to try and spray it up into the threads of the bolt as much as you can. You may want to replace that bolt, I know you sayed you don't want to, but I would. And be patient, if you rush you'll end up snappiing the bolt and having to buy new heads or get the hole rebored at a shop, either way sucks.
Old Aug 5, 2005
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Look here
Old Aug 5, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
^^exactly. But if you really do not care too much about the old bolt or header just thread the other bolt back it(for support) then dremel the bolt off. Other wise like stated before just lube it up and go slow it should break free!
Tedverseti
Apr 23, 2020 01:45 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
